Hi! I have a technical type of question. We did search for an answer in the google for 2 hours and did not find anything useful, small and not expensive.
We simple do not know how to implement the following into the JIRA:
For example we have a status called "Open" and from this status there is a transition to another status called "Freezed". When we do the transition, the screen with Date picker or Date Time picker custom field shows up and we manually enter the date (For example x days from now).
Until this moments it`s all clear. All default JIRA functionality. Now comes the tricky part. We wan`t to make it that after x days (In date, which you entered in the field) this issue automatically moves back to status "Open".
Can you guys please advise how can we accomplish this with most fastest and easiest way. We already have setup Script Runner in our JIRA system, maybe we can accomplish it with that but my knowledge is not good, maybe you guys can give me some tips.
Thankyou!
Automation Lite (and its paid counterpart Automation) also offers escalation features: https://marketplace.atlassian.com/plugins/com.atlassian.plugin.automation.jira-automation-plugin/server/overview
In comparison to ScriptRunner, you may save some programming efforts with this, but if you need more flexibility, then it is ScriptRunner.
You can use Escalation Service in ScriptRunner. Escalation service let you transtion issues which are selected by JQL query. Your JQL query would be like this
customfield is not empty and customfield < startOfDay()
JQL query would be checked periodically. In your case you can define the period as 1 day. You can read more about it here:
https://scriptrunner.adaptavist.com/4.3.1/jira/escalation-service.html
Help us plant more trees
