Steps:
- Download latest version of JIRA for Windows 7 (64 bit installer)
- Install JIRA to run as standalone (not as a service)
- Execute startup_bundled_jre.bat from command window
- Java starts and eventually shuts down
See attached log entries below:
15-May-2012 9:09:55 AM org.apache.catalina.core.StandardServer await
SEVERE: StandardServer.await: create 8005 :
java.net.BindException: Cannot assign requested address: JVM_Bind
at java.net.PlainSocketImpl.socketBind(Native Method)
at java.net.PlainSocketImpl.bind(PlainSocketImpl.java:383)
at java.net.ServerSocket.bind(ServerSocket.java:328)
at java.net.ServerSocket.<init>(ServerSocket.java:194)
at org.apache.catalina.core.StandardServer.await(StandardServer.java:406)
at org.apache.catalina.startup.Catalina.await(Catalina.java:676)
at org.apache.catalina.startup.Catalina.start(Catalina.java:628)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414)
15-May-2012 9:09:56 AM org.apache.coyote.http11.Http11Protocol pause
INFO: Pausing Coyote HTTP/1.1 on http-8080
15-May-2012 9:09:57 AM org.apache.catalina.core.StandardService stop
INFO: Stopping service Catalina
15-May-2012 9:09:57 AM org.apache.catalina.loader.WebappClassLoader clearReferencesThreads
SEVERE: The web application appears to have started a thread named Spring executor 1 but has failed to stop it. This is very likely to create a memory leak.
SEVERE: The web application appears to have started a thread named Spring executor 2 but has failed to stop it. This is very likely to create a memory leak.
SEVERE: The web application appears to have started a thread named Spring executor 3 but has failed to stop it. This is very likely to create a memory leak.
SEVERE: The web application appears to have started a thread named Spring executor 4 but has failed to stop it. This is very likely to create a memory leak.
SEVERE: The web application appears to have started a thread named Spring executor 5 but has failed to stop it. This is very likely to create a memory leak.
SEVERE: The web application appears to have started a thread named Spring executor 6 but has failed to stop it. This is very likely to create a memory leak.
SEVERE: The web application appears to have started a thread named Spring executor 7 but has failed to stop it. This is very likely to create a memory leak.
15-May-2012 9:09:57 AM org.apache.catalina.loader.WebappClassLoader clearThreadLocalMap
SEVERE: The web application created a ThreadLocal with key of type java.lang.ThreadLocal (value java.lang.ThreadLocal@11ba1db5 ) and a value of type org.dom4j.DocumentFactory (value org.dom4j.DocumentFactory@51f45f2a ) but failed to remove it when the web application was stopped. This is very likely to create a memory leak.
SEVERE: The web application created a ThreadLocal with key of type com.google.inject.internal.InjectorImpl$1 (value com.google.inject.internal.InjectorImpl$1@3c80d0bb ) and a value of type java.lang.Object (value Ljava.lang.Object;@2d07c405 ) but failed to remove it when the web application was stopped. This is very likely to create a memory leak.
15-May-2012 9:09:57 AM org.apache.coyote.http11.Http11Protocol destroy
INFO: Stopping Coyote HTTP/1.1 on http-8080
We tried a number of things to resolve this issue. Netstat showed that port 8005 was available. But JIRA would not bind to it. The machine is a member of AD and is regulated by Group Policy. Changing the port to 7005 made it work without issue.
Do not worry this is just becasue the installer is crap just like the java itself, even if it's ask you about the ports it's still use the default port for many things, shutdownport and etc, so you need to find them in the /conf/web.xml override them and then you will have a better chance to run that that ... something.
A number of causes that should be investigated:
1) port 8005 is in use, probably lingering
2) you try to bind port 8005 on the wrong IP (the configured ip is not the one from your box)
