GIT Migration from Redmine
Nawaaz SOHAWON
I am trying to migrate the Git from Redmine to JIRA cloud.
I have used the Git Integration for JIRA add on and used the 'Connect to Basic Git Repository' option and entered the https for Redmine GIT.
Question: is there a way to completely migrate the GIT from Redmine to JIRA completely?
Nawaaz
2 accepted
Nawaaz SOHAWON
Thanks for your response Aron.
I will check your suggestion. Would you not happen to have a guide on moving GIT fro Redmine to Bitbucket?
Thanks again
Aron Gombas _Midori_
April 4, 2018
I described that in my last sentence above:
You can easily import an existing Git repo to Bitbucket by adding Bitbucket as a remote, then pushing the existing repo to that remote.
Although this guide is written for Bitbucket server, the idea should be the same for Bitbucket Cloud, too.
Nawaaz SOHAWON
Thank you
April 4, 2018
If it helped, remember to click the checkmark next to the answer, so that future users can see that.
April 3, 2018 edited
Jira is an issue tracker, therefore it will not provide you with a Git repository.
But:
1. Atlassian has another cloud based offering called Bitbucket, which is a hosted Git service.
2. Jira and Bitbucket are seamlessly integrated and play really nicely together.
atlassian, loom, AI, meeting recording, community
[NEW] Record your meetings with Loom
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
Learn more
