GNU Bash 4.3 - CVE-2014-6271 vulnerability issue - How does Altassian tools impacted?
Jijo John
Bash  - CVE-2014-6271 vulnerability issue - How does Altassian tools impacted? especially JIRA and Bamboo (Running on Centos 5.4 OS).
how that differ Cloud hosting and standalone installation?
Jijo | TechNPoints
craig_davies
September 26, 2014
Hi all
There is no vulnerability in Atlassian server products, see my blog post.
http://blogs.atlassian.com/2014/09/bash-vulnerability-atlassian/
Jijo John
Thanks Craig for confirmation! Good to hear from Atlassin people directly :)
Nic Brough -Adaptavist-
September 26, 2014
Atlassian systems, both OnDemand and Server versions, are not affected by this bug generally, barring two cases:
  1.  Bitbucket was vulnerable, but has been patched
  2. Where you have installed server versions on systems that are affected.  Atlassian stuff itself is not affected directly, but if they're running on an OS that is affected, then yes, they're vulnerable.  So you need to fix it at an OS level if you're using a vulnerable version of bash.
Jijo John
Thanks Nic, That make sense since Bash is part of OS component.
Chag
September 26, 2014
I think you just need to patch up your linux to fix the vulnerability. Any software can be exposed with this bash issue. They put out a temporary patch you should update to that and when a complete fix has been done update to that.
Chag
September 26, 2014
for the cloud issue I have not heard atlassian mention anything yet.  nothing listed in their https://confluence.atlassian.com/display/JIRA/Security+Advisories
