Hello, everyone. I’m writing Jira gadget and I want to add a possibility to edit user preferences. The problem I have, is that I don’t understand how to handle “Edit” click and submit button. So, when user clicks “Edit” I want to hide the current gadget content. And when user clicks “Save” (in html tags this is submit) I want to handle this by reloading gadget content with new user preferences.
Hey Peter, I'm in this stage and I found out how to display the config form before rendering the view:
<?xml version="1.0" encoding="UTF-8" ?>
<Module>
<ModulePrefs title="__MSG_gadget.title__" directory_title="__MSG_gadget.title__" description="__MSG_gadget.description__">
<Optional feature="gadget-directory">
<Param name="categories">JIRA</Param>
</Optional>
<Require feature="setprefs" />
<Require feature="views" />
<Require feature="dynamic-height" />
<Require feature="oauthpopup" />
<!-- OAuth configuration -->
<Locale messages="__ATLASSIAN_BASE_URL__/download/resources/com.atlas.tuto.atlastuto/i18n/ALL_ALL.xml"/>
</ModulePrefs>
<UserPref name="isConfigured" datatype="hidden" default_value="false" />
<UserPref name="projectKey" datatype="hidden" />
<Content type="html" view="profile">
<![CDATA[
#requireResource("com.atlassian.jira.gadgets:common")
#requireResource("com.atlassian.gadgets.publisher:ajs-gadgets")
#includeResources()
<!-- Chart.js CDN -->
<script src="https://cdn.jsdelivr.net/npm/chart.js"></script>
<style>
/* Set a fixed height for the chart */
#chart-container {
width: 100%;
height: 300px; /* Adjust height as needed */
padding: 10px 0;
</style>
<script type="text/javascript">
(function () {
var gadget = AJS.Gadget({
baseUrl: "__ATLASSIAN_BASE_URL__",
useOauth: false,
config:{
descriptor: function(args){
var gadget = this;
return {
theme: "",
fields:[
userpref: "projectKey",
class: "projectKey",
label: "Select the project",
description: "Find the project to apply the chart",
type: "text",
value: gadget.getPref("projectKey")
userpref: "isConfigured",
type: "hidden",
value: "true"
view: {
template: function(args) {
var gadget = this;
var chartContainer = AJS.$("<div/>").attr({ id: "chart-container" });
var chartCanvas = AJS.$("<canvas/>").attr({ id: "myChart" });
chartContainer.append(chartCanvas);
gadget.getView().html(chartContainer);
var ctx = chartCanvas[0].getContext("2d");
new Chart(ctx, {
type: 'line',
data: {
labels: ['January', 'February', 'March', 'April', 'May', 'June', 'July'],
datasets: [
label: 'Tickets',
data: Array.from({length: 7}, () => Math.floor(Math.random() * 100)),
borderColor: 'rgba(255, 99, 132, 1)',
backgroundColor: 'rgba(255, 99, 132, 0.2)',
fill: false
label: 'Solved',
borderColor: 'rgba(54, 162, 235, 1)',
backgroundColor: 'rgba(54, 162, 235, 0.2)',
fill: false
label: 'Remain',
borderColor: 'rgba(75, 192, 192, 1)',
backgroundColor: 'rgba(75, 192, 192, 0.2)',
fill: false
options: {
responsive: true,
maintainAspectRatio: false,
scales: {
y: {
beginAtZero: true,
max: 100
args: [{
key: "projectData",
ajaxOptions: function() {
return {
url: "/rest/gadgetresource/1.0/message",
contentType: "application/json"
</script>
</Content>
</Module>
My problem now is the submit and the cancel button appear without text and I'm looking to change the text of the edit button.
Register now
