×Dear all, I try to make a good dashboard for having an overview of my change requests. To see wich of them are already in work I need to see the linked issues. And it makes most sense for me to see wich type they have. For example I can see that there is already a task for one of my requests or there is a bug on one of them.
Is there a way to show the the linked issues in the column in the filter result gadget by their type symbols instead of their key?
Thank you!
No this is not possible. As an issue has multiple linked issues, all issues are displayed in the same column, but they can be of a different type.
Thank you for this answer. I know that, I just want to change from seeing the keys of the linked issues into the symbols of their types. But this seems to be impossible in Jira.
