Gadget titles showing as __MSG_gadget
Laurent Bierge
April 30, 2018
I'm currently in 7.2.2 version but i have a test instance (identical) in 7.8.3 version.
I'm having this known issue. (see title)
My Jira is behind a reverse proxy (apache), and i configured it as described in:
https://confluence.atlassian.com/adminjiraserver071/integrating-jira-with-apache-using-ssl-802593043.html\\
I've checked this kb:
https://confluence.atlassian.com/jirakb/how-to-fix-gadget-titles-showing-as-__msg_gadget-813697086.html\\ But i didn't manage to find the solution for my problem.
In my server.xml, i have two connector.
One (let say port 8080) to communicate with apache and another one (port 8090) to directly connect to Jira without going through the reverse proxy.
When i'm using http://@ServerIp:8090 i have the corect name for the gadget, but when i use https://jira.server.domain.com i have __MSG_gadget...
I did my first test with Apache without SSL, and gadget displayed right names. Since my Apache went using SSL i don't have good gadget name anymore.
On a dev instance (with the same configuration and architecture), i tried to upgrade to 7.8 in case it was the SAN certificat problem but it didn't do any good.
All my certificat are in the cacert file. i cannot curl -v localhost, but i've never be able to do so. (even when the gadget name was showing correctly).
Well to sum up, i've tried all the resolution in the Kb and nothing worked...
Any idea of what could fix my issue?
Laurent
Laurent Bierge
May 28, 2018
Since there is no update, the answer may be linked to the way i imported certificate.
With : keytool -keystore cacerts -importcert...
it doesn't work.
With : keytool -import -trustcacerts -alias... -keystore cacerts
it works.
Laurent
Chris Nelson October 30, 2018
This answer would be more helpful without ellipsis.
Laurent Bierge
November 5, 2018
Hi Chris,
The "hide" content is just bellow.
Laurent
Tom van Heesbeen
January 17, 2020
I had the same issue. Yet my gadgets where not loading because the server itself couldn't reach jira once i had installed the SSL certificate. Once the server was able to reach the jira site all plugins started working again.
Kurt Klinner
April 30, 2018
@Laurent Bierge
Hi Laurent,
can you share your server.xml (are proxyName, proxyPort and scheme correctly set)
Did you check the log files as well?
BR
Kurt
Laurent Bierge
May 2, 2018
Thank you for your answer Kurt !
My server.xml should be set as described in "integrating jira with apache using ssl":
<Connector port="8080"
maxThreads="150"
minSpareThreads="25"
connectionTimeout="20000"
enableLookups="false"
maxHttpHeaderSize="32768"
protocol="HTTP/1.1"
useBodyEncodingForURI="true"
acceptCount="100"
disableUploadTimeout="true"
redirectPort="8443"
proxyName="domainName"
proxyPort="443"
scheme="https"
Well, i've checked for the error in the kb i mentionned, Other than that, idon't know what to check.
Laurent
Kurt Klinner
May 3, 2018
@Laurent Bierge
Can you share your apache config as well?
Are there any additional information in the log file?
Laurent Bierge
May 4, 2018
It seems that my problem is solved.
The cause may have been the way that i import certificat in the cacert file.
Usually i use: keytool -keystore cacerts -importcert...
and this time i used: keytool -import -trustcacerts -alias... -keystore cacerts
What do you think ?
Register now
