Generate User based Acces token to access Jira REST APIs.
venu gowda March 21, 2019
Hi, We have business scenario, where we would like access jira rest APIs, to authenticate rest APIs we would like use the Access Token, I refered to the follwing url https://developer.atlassian.com/server/jira/platform/oauth/ this generates a system token.
what we want is user specific token.  So that when we run the API it will use user roles.I have not find any ways to do that. could you please help me with some documentation how we can do that. or is it possible to do it or not.
Andy Heinzer
March 28, 2019
Hi Venu,
In the guide you cited, the steps that you take to configure Oauth to work with Jira does generate a user specific access code or token.
Step 3. Make an authenticated request to the Jira REST API
An access code is all that we need to make an authenticated request to the Jira REST API. Requests are made as the user who authorized the initial request token. The access token will persist for 5 years, unless it is revoked.
The user that creates this code is the same user that these API calls would be made as when authenticating to Jira using this access code.
I hope this helps.
Andy
