Sign up Log in
Generate custom reports
Munal Santra
January 4, 2012
I am a new user for Jira and was wondering if there is a way to generate custom reports instead of the preset parameters?
4 votes
Raimonds Simanovskis
January 30, 2012
Take a look on eazyBI reporting application with JIRA integration. It will perform regular import from JIRA and will create several pre-defined sample reports as well as you can create custom reports using any standard JIRA fields as well as selected custom fields. You can create reports, charts and dashboards in easy drag-and-drop style.
November 13, 2012
Now also installable eazyBI reports and charts plugin for JIRA is available from Atlassian Marketplace.
6 votes
All-In-One Support
September 29, 2014
You can try https://www.jirareports.com. It is a cloud based tool that allows creation of free form reports for OnDemand and hosted Jira instances. It offers different types of reports such as bar chart, matrix reports etc. and has a rich set of features available, such as publishing the reports, calculated fields and export capabilities.
JiraReports
Thomas O'Grady
March 11, 2019
Link does not work?
Like • 3 people like this
Navarambh Software - Gmail
June 29, 2019 edited
Here is the updated link for the App: AIO Reports and Timesheets for Jira, one of the Top Selling reporting Apps for Jira!
Regards
AIO Support
Maksim_Feshchanka
January 14, 2020 edited
Thank you for reporting this. The link has been fixed now. Below is the link again:
https://marketplace.atlassian.com/apps/1212942/aio-reports-and-timesheets-for-jira
Like • Maksim_Feshchanka likes this
Maksim_Feshchanka
Thanks, it works now.
5 votes
Tim Watts
Coming slightly late to the party I have a couple of comments:
1) I'm somewhat disappointed by the lack of an inbuilt generic reporting tool. Eg I spend some time maintaining work logs in detail. Can I find or create a report to summarise my work logs by label, by project, by task (rolling up sub tasks)? So far, the answer seems to be "no".
2) Reporting add-ons at x-thousand dollars (for 500 users) is fair enough of the tool is super advanced - but this is not really an excuse for the lack of basic customisable reporting in Jira (which already costs x-thousand dollars). That's a personal rant - even Microsoft offer more flexibility when you buy their software. Yes I know about the more basic and much cheaper Timesheep add on, but this solves the example problem above and then you are back to square one.
3) One thing that everyone seems to have overlooked is: just run SQL queries against the underlying database. Add perl if the reports need to be more complex/web based/pretty. This is *exactly* what perl and SQL were made for. Replace perl with sensible scripting language of choice. So far, it seems the database is clean and lends itself to this type of querying.
Given that I'm not about to ask to spend large amounts of money, I will go with option 3 :)
Still disappointed...
4 votes
Jüri Kaljundi
You can generate daily, weekly or monthly reports using Weekdone JIRA reporting and dashboards add-on: https://marketplace.atlassian.com/plugins/com.weekdone.atlassian-connect.jira
It's mainly to get a really quick and simple visual overview of how you or your team is doing.
Consulente Atlassian
It's a shame that there is no server version
Marcel Nick April 26, 2017 edited
Hi Munal,
Also take a look at VIEW26 - Insights & Reporting for Software Testing on JIRA available on Atlassian marketplace.
VIEW26 brings to you features like instant charts & KPI, Plug n Play integration to popular testing tools like Zephyr, TestRail, HP-ALM etc, aggregation and correlation of data across multiple tools, one click sharing of reports and many more.
mwarton
October 9, 2013
Hi Munal,
Have you seen the Intelligent Reports plugin? It lets you design your templates in Word for easy formatting, then fill in the templates with simple, powerful point and click rules. You can do charts, tables, custom fields, work logs, issue history, projects, versions, components, etc. Try it out and see if it meets your needs.
Midori
November 9, 2012
Many users succeed with implementing custom reports using the JIRA PDF View Plugin.
Sample reports:
  1. Sales report
  2. Gantt project report
  3. Traceability report
The plugin at Marketplace: https://marketplace.atlassian.com/5167
Tutorials:
  1. Implementing your reporting logic
  2. Drawing charts in the reports
  3. Bringing it all together (customization guide)
(Discl: this plugin is our product.)
Tudor Hofnar
Thanks Ferenc, does this plugin work with OnDemand JIRA?
Midori
November 13, 2012
unfortunately not.
OnDemand does not allow 3rd party plugins at the moment, although Atlassian is actively working on a technology called "remote plugins" (aka "plugin three") that allows to integrate external plugins with OnDemand. as soon as it goes into production, we will leverage it.
Audrey Gil
April 12, 2012
Is this the only solution to create reports in JIRA?
Are creating filters and exporting to Excel or Word, etc. the only capabiliy JIRA has within the system?
Tudor Hofnar
any answer to this question? I am also looking for more detail about reporting, without having to use another tool for another $50/month
All-In-One Support
September 29, 2014
Hi, You can try https://www.jirareports.com. It is a cloud based tool that allows creation of free form reports for OnDemand and hosted Jira instances. It offers different types of reports such as bar chart, matrix reports etc. and has a rich set of features available, such as publishing the reports, calculated fields and export capabilities. Thanks JiraReports
Riaz Raza January 4, 2021
This has been my biggest frustration, but then I was able to connect Jira with Power BI using Jira APIs. I have made it opensource and you can get it from here,
https://github.com/KoderLabs/jira-powerbi-template
Using Power BI, you can create all sort of reports you want without much hassle. Before going with Power BI, I tried creating a plugin, but creating a plugin for every report takes too much time and is too much hassle to manage a lot of reports.
Evgeny Zislis October 29, 2012
You can create your own plugins, there is a tutorial that explains it in detail on the Atlassian wiki - https://developer.atlassian.com/display/JIRADEV/Plugin+Tutorial+-+Creating+a+JIRA+Report
