Get Active Sprint from project
Dan27
I would like to get the active sprint + the 3 older sprints before it, from a project. I write the code with script field.
How can I do it?
miikhy
June 13, 2018
Hi Daniel!
It's going to be challenging: sprints are associated with boards, not projects. That being said, a board can be based on a project (all project scope) but you can also have multiple boards for a single project! The idea coming to my mind would be to get the sprint list associated with boards and get the board scope but that's definitely a tricky one!
Hope this helps!
Cheers
Dan27
Thanks! I will work on board,
So how can I get the active sprint + the 3 older sprints before it from the board? :)
Alexey Matveev
June 13, 2018
Kidnly have a look at this example:
https://gist.github.com/jechlin/9789183
miikhy
June 13, 2018
Which is great for active sprint (as long as you have only one) but won't work for the last 3 sprints. Maybe something can be done with Sprint IDs?
That's definitely the sprintManager which will help and that example is a great start point which will just need a few more tweaks @Dan27 :)
Dan27
I have errors:
Can't find the functions: getRapidView , getSprintsForView.
I have all of the imports... Do you have any suggestions ?
Like Mikhail Kosenko likes this
Alexey Matveev
June 13, 2018
@Dan27 where do you run the script?
Dan27
Script field of Script Runner
Alexey Matveev
June 13, 2018
Try first in the Script Console and kindly provide erros
package examples.docs
import com.atlassian.greenhopper.service.rapid.view.RapidViewService
import com.atlassian.greenhopper.service.sprint.SprintIssueService
import com.atlassian.greenhopper.service.sprint.SprintManager
import com.onresolve.scriptrunner.runner.customisers.JiraAgileBean
import com.onresolve.scriptrunner.runner.customisers.WithPlugin
* Configurable section
// Enter the name of the board to which you want to add the issue to the first active sprint
def rapidBoardId = 2L
@WithPlugin("com.pyxis.greenhopper.jira")
@JiraAgileBean
RapidViewService rapidViewService
@JiraAgileBean
SprintIssueService sprintIssueService
@JiraAgileBean
SprintManager sprintManager
Issue issue = ComponentAccessor.getIssueManager().getIssueObject("your issue key")
def loggedInUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def view = rapidViewService.getRapidView(loggedInUser, rapidBoardId).getValue()
if (! view) {
log.warn("No view with this ID found")
return
def sprints = sprintManager.getSprintsForView(view).getValue()
def activeSprint = sprints.find { it.active }
log.debug activeSprint
if (activeSprint) {
log.info "Adding issue $issue to ${activeSprint.name}"
sprintIssueService.moveIssuesToSprint(loggedInUser, activeSprint, [issue] as Collection)
else {
log.info ("No active sprints were found for board: ${view.name}")
Dan27
Thank you!
I found only Board key and name, hoe can I find the id ?
Alexey Matveev
June 13, 2018
When you open a board, have a look at the url. There must be something like rapidview=<numeric>. This numeric is the id.
Dan27
111.png@Alexey Matveev Can you please help me understanding this error ?
Dan27
Hi @Alexey Matveev and @miikhy ,
I succeed to take the active sprint, now I would like to get the 2 previous sprints.
Do you have an idea how can I do it ?
Daniel
