Get List of users added in a Project Role using Script Runner Console
Vikrant Yadav
Hi Guys,
Need your help in getting list of users added in a Project Roles using Script Runner. I want list of users added in a particular project.
Here is code i define names = projects name for which i need users list.
But not sure where to insert names to get list of users of these two projects only. Kindly suggest.
import com.atlassian.jira.project.Project
import com.atlassian.jira.project.ProjectManager
import com.atlassian.jira.security.roles.ProjectRole
import com.atlassian.jira.security.roles.ProjectRoleActors
import com.atlassian.jira.security.roles.ProjectRoleManager
def projectManager = ComponentAccessor.getProjectManager()
def projectRoleManager = ComponentAccessor.getComponent (ProjectRoleManager)
def sb = new StringBuffer()
//array of project names
//def names = ["AgeingWorks", "Self Service Portal"]
ProjectRole devsRole = projectRoleManager.getProjectRole("Developers")
def result = ""
projectManager.getProjectObjects().each {Project project ->
ProjectRoleActors actors = projectRoleManager.getProjectRoleActors(devsRole, project)
result += "$project.key, $project.name, $project.lead, ${actors.getUsers()*.name}\n"
return result
 Thanks in Advance!
7 votes
Hana Kučerová
Hi @Vikrant Yadav ,
I would do something like:
final String projectRoleName = 'Developers'
final List<String> projectKeys = ['ABC', 'CDE']
ProjectManager projectManager = ComponentAccessor.getProjectManager()
ProjectRoleManager projectRoleManager = ComponentAccessor.getComponent(ProjectRoleManager)
ProjectRole projectRole = projectRoleManager.getProjectRole(projectRoleName)
String result
projectKeys.each{ String projectKey ->
Project project = projectManager.getProjectObjByKey(projectKey)
if (project) {
ProjectRoleActors actors = projectRoleManager.getProjectRoleActors(projectRole, project)
result += "$project.key, $project.name, $project.leadUserKey, ${actors.getUsers()*.name}\n"
return result
ABC and CDE needs to be replaced by your projects' keys (not names!)
I changed the way the script works - if you don't need other projects, why iterate through them :-).
Vikrant Yadav
@Hana Kučerová  Awesome, it works for me :) . Eager to learn more from you.
What is "ProjectRoleActors" ?
What does it means { String projectKey ->
projectManager is used to call Project roles ?
Thanks a lot, Mate!
Vikrant Yadav
@Hana Kučerová  Instead of username , is it possible to display full name ?😜
Hana Kučerová
@Vikrant Yadav please try to use
project.projectLead.displayName
instead of
project.leadUserKey
