Get Required/mandatory transition fields using REST API
Srilatha Pokala
Following is the URL i am using to get list of Transitions and fields on each transition.
/rest/api/2/issue/{issueIdOrKey}/transitions?expand=transitions.fields
API does not seem to be returning correct field attributes like required attribute.
I see many of the fields as required when i click on tranistion but the API returns as required:false for every field.
Is there something wrong API i am using or any setting that is available?
Your help is appreciated.
Chander Inguva
June 6, 2017
Hey Srilatha,
The API endpoint is right and i cannot reproduce the issue. Are you using any custom post functions or behaviours on transitons ?
Srilatha Pokala
Thank you for the response.
Yes, we do set required fields in workflow Validator.
"Fields required during a workflow transition" is avaiable thru JIRA Suite Utilities plugin.
David Georgy
June 18, 2018
