Get data from Issue ActivityStream
Fábio Antunes
Hi there,
I would like to know how could I get data from the Issue ActivityStream, preferably,  using the Java API.
Kind Regards,
Fábio Antunes
teilor_soares
July 28, 2015
It's not possible to get data from the Issue ActivityStream through the REST API, but you can use Streams Atom feeds to get and filter the data https://developer.atlassian.com/docs/atlassian-platform-common-components/activity-streams/consuming-an-activity-streams-feed
Cheers!
Teilor
Fábio Antunes
Hi @Teilor Soares , Thank you so much, I am already able to get all feed content. Now im facing another problem converting the feed to html using the JIRA styles applied to the elements. Is there a way to achieve that ? Kind Regards, Fábio Antunes
