I am working on JIRA Bug Analysis. I am accessing JIRA using REST V2 APIs using JQL like
Hello @soumya awasthi
Which API endpoint are you calling, specifically?
I think you need to use this endpoint instead, and look at the fields parameter that are available for that API endpoint.
I checked, but this fields parameter doesn't have all data like closing reason, root cause.
I want to access all the fields which we get when we Export-> Excel(all fields) option from the JIRA UI.
For predictive analysis of bug these features are crucial.
Thank you in advance.
Hi Trudy,
Thank you. I was able to identify the field. It was the custom field.
You're welcome.
If my responses helped you solve your requirement, please consider clicking on the Accept Answer button to mark your Question as Solved.
