when i fellow the tutorial of your website at https://developer.atlassian.com/docs/getting-started/learn-the-development-platform-by-example/create-a-plugin-skeleton,before the Step 2. Start up the RefApp everything is ok.When i run "atlas-run" as the second step of "Step 2. Start up the RefApp" said occurred an error。
i have finished this chapter and there is no problem:https://developer.atlassian.com/docs/getting-started/set-up-the-atlassian-plugin-sdk-and-build-a-project
how to handle this?
[INFO] [talledLocalContainer] ERROR - 14:58:13,921 - assian.plugin.osgi.container.felix.FelixOsgiContainerManager - [FelixDispatchQueue] - Framework error in bundle com.atlassian.devrel.developer-toolbox-plugin
[INFO] [talledLocalContainer] org.osgi.framework.BundleException: Unresolved constraint in bundle com.atlassian.devrel.developer-toolbox-plugin [26]: Unable to resolve 26.0: missing requirement [26.0] osgi.wiring.package; (osgi.wiring.package=com.atlassian.labs.restbrowser.plugin) [caused by: Unable to resolve 33.0: missing requirement [33.0] osgi.wiring.package; (osgi.wiring.package=com.atlassian.templaterenderer.velocity.one.six)]
[INFO] [talledLocalContainer] at org.apache.felix.framework.Felix.resolveBundleRevision(Felix.java:3974)
[INFO] [talledLocalContainer] at org.apache.felix.framework.Felix.loadBundleClass(Felix.java:1824)
[INFO] [talledLocalContainer] at org.apache.felix.framework.BundleImpl.loadClass(BundleImpl.java:937)
[INFO] [talledLocalContainer] at com.atlassian.plugin.osgi.util.BundleClassLoaderAccessor$BundleClassLoader.findClass(BundleClassLoaderAccessor.java:66)
[INFO] [talledLocalContainer] at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
[INFO] [talledLocalContainer] at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
[INFO] [talledLocalContainer] at java.util.ResourceBundle$Control.newBundle(ResourceBundle.java:2640)
[INFO] [talledLocalContainer] at java.util.ResourceBundle.loadBundle(ResourceBundle.java:1501)
[INFO] [talledLocalContainer] at java.util.ResourceBundle.findBundle(ResourceBundle.java:1465)
[INFO] [talledLocalContainer] at java.util.ResourceBundle.getBundleImpl(ResourceBundle.java:1361)
[INFO] [talledLocalContainer] at java.util.ResourceBundle.getBundle(ResourceBundle.java:1082)
[INFO] [talledLocalContainer] at com.atlassian.refapp.sal.message.ResourceBundleResolverImpl.getBundle(ResourceBundleResolverImpl.java:10)
[INFO] [talledLocalContainer] at com.atlassian.refapp.sal.message.RefimplI18nResolver.getBundle(RefimplI18nResolver.java:205)
[INFO] [talledLocalContainer] at com.atlassian.refapp.sal.message.RefimplI18nResolver.access$200(RefimplI18nResolver.java:39)
[INFO] [talledLocalContainer] at com.atlassian.refapp.sal.message.RefimplI18nResolver$2.get(RefimplI18nResolver.java:93)
[INFO] [talledLocalContainer] at com.atlassian.refapp.sal.message.RefimplI18nResolver$2.get(RefimplI18nResolver.java:87)
[INFO] [talledLocalContainer] at com.atlassian.util.concurrent.ManagedLocks$ManagedLockImpl.withLock(ManagedLocks.java:303)
[INFO] [talledLocalContainer] at com.atlassian.refapp.sal.message.RefimplI18nResolver.getPattern(RefimplI18nResolver.java:87)
[INFO] [talledLocalContainer] at com.atlassian.refapp.sal.message.RefimplI18nResolver.resolveText(RefimplI18nResolver.java:70)
[INFO] [talledLocalContainer] at com.atlassian.sal.core.message.AbstractI18nResolver.getText(AbstractI18nResolver.java:31)
[INFO] [talledLocalContainer] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[INFO] [talledLocalContainer] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
[INFO] [talledLocalContainer] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
[INFO] [talledLocalContainer] at java.lang.reflect.Method.invoke(Method.java:498)
[INFO] [talledLocalContainer] at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:302)
[INFO] [talledLocalContainer] at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:56)
[INFO] [talledLocalContainer] at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:60)
[INFO] [talledLocalContainer] at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
[INFO] [talledLocalContainer] at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:133)
[INFO] [talledLocalContainer] at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:121)
[INFO] [talledLocalContainer] at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.java:70)
[INFO] [talledLocalContainer] at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invoke(ServiceTCCLInterceptor.java:53)
[INFO] [talledLocalContainer] at org.eclipse.gemini.blueprint.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:57)
[INFO] [talledLocalContainer] at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:208)
[INFO] [talledLocalContainer] at com.sun.proxy.$Proxy248.getText(Unknown Source)
[INFO] [talledLocalContainer] at com.atlassian.upm.core.log.AuditLogEntryImpl.getMessage(AuditLogEntryImpl.java:58)
[INFO] [talledLocalContainer] at com.atlassian.upm.core.log.PluginSettingsAuditLogService.log(PluginSettingsAuditLogService.java:94)
[INFO] [talledLocalContainer] at com.atlassian.upm.core.log.PluginSettingsAuditLogService.logI18nMessageWithCurrentApplication(PluginSettingsAuditLogService.java:73)
[INFO] [talledLocalContainer] at com.atlassian.upm.log.ApplicationLifecycleLoggerImpl.onStart(ApplicationLifecycleLoggerImpl.java:19)
[INFO] [talledLocalContainer] at com.atlassian.sal.core.lifecycle.DefaultLifecycleManager$4.consume(DefaultLifecycleManager.java:277)
[INFO] [talledLocalContainer] at com.atlassian.sal.core.lifecycle.DefaultLifecycleManager$4.consume(DefaultLifecycleManager.java:274)
[INFO] [talledLocalContainer] at com.atlassian.sal.core.lifecycle.DefaultLifecycleManager.notifyLifecyleAware(DefaultLifecycleManager.java:303)
[INFO] [talledLocalContainer] at com.atlassian.sal.core.lifecycle.DefaultLifecycleManager.notifyOnStartIfStartedAndEnabled(DefaultLifecycleManager.java:273)
[INFO] [talledLocalContainer] at com.atlassian.sal.core.lifecycle.DefaultLifecycleManager.access$300(DefaultLifecycleManager.java:49)
[INFO] [talledLocalContainer] at com.atlassian.sal.core.lifecycle.DefaultLifecycleManager$3.evaluate(DefaultLifecycleManager.java:235)
[INFO] [talledLocalContainer] at com.atlassian.sal.core.lifecycle.DefaultLifecycleManager$3.evaluate(DefaultLifecycleManager.java:232)
[INFO] [talledLocalContainer] at com.atlassian.sal.core.lifecycle.DefaultLifecycleManager.notifyLifecycleAwares(DefaultLifecycleManager.java:258)
[INFO] [talledLocalContainer] at com.atlassian.sal.core.lifecycle.DefaultLifecycleManager.notifyStartableLifecycleAwares(DefaultLifecycleManager.java:231)
[INFO] [talledLocalContainer] at com.atlassian.sal.core.lifecycle.DefaultLifecycleManager.startIfApplicationSetup(DefaultLifecycleManager.java:219)
[INFO] [talledLocalContainer] at com.atlassian.sal.core.lifecycle.DefaultLifecycleManager.onPluginFrameworkStarted(DefaultLifecycleManager.java:152)
[INFO] [talledLocalContainer] at com.atlassian.plugin.event.impl.MethodSelectorListenerHandler$1$1.invoke(MethodSelectorListenerHandler.java:42)
[INFO] [talledLocalContainer] at com.atlassian.event.internal.AsynchronousAbleEventDispatcher$1$1.run(AsynchronousAbleEventDispatcher.java:46)
[INFO] [talledLocalContainer] at com.google.common.util.concurrent.MoreExecutors$DirectExecutorService.execute(MoreExecutors.java:299)
[INFO] [talledLocalContainer] at com.atlassian.event.internal.AsynchronousAbleEventDispatcher.dispatch(AsynchronousAbleEventDispatcher.java:105)
[INFO] [talledLocalContainer] at com.atlassian.event.internal.EventPublisherImpl.invokeListeners(EventPublisherImpl.java:160)
[INFO] [talledLocalContainer] at com.atlassian.event.internal.EventPublisherImpl.publish(EventPublisherImpl.java:79)
[INFO] [talledLocalContainer] at com.atlassian.plugin.event.impl.DefaultPluginEventManager.broadcast(DefaultPluginEventManager.java:73)
[INFO] [talledLocalContainer] at com.atlassian.plugin.manager.DefaultPluginManager.broadcastIgnoreError(DefaultPluginManager.java:2081)
[INFO] [talledLocalContainer] at com.atlassian.plugin.manager.DefaultPluginManager.lateStartup(DefaultPluginManager.java:654)
[INFO] [talledLocalContainer] at com.atlassian.plugin.refimpl.ContainerManager$PluginPhaseTriggers$1.onSuccess(ContainerManager.java:342)
[INFO] [talledLocalContainer] at com.atlassian.plugin.refimpl.ContainerManager$PluginPhaseTriggers$1.onSuccess(ContainerManager.java:339)
[INFO] [talledLocalContainer] at com.google.common.util.concurrent.Futures$6.run(Futures.java:1319)
[INFO] [talledLocalContainer] at com.google.common.util.concurrent.MoreExecutors$DirectExecutor.execute(MoreExecutors.java:457)
[INFO] [talledLocalContainer] at com.google.common.util.concurrent.ExecutionList.executeListener(ExecutionList.java:156)
[INFO] [talledLocalContainer] at com.google.common.util.concurrent.ExecutionList.execute(ExecutionList.java:145)
[INFO] [talledLocalContainer] at com.google.common.util.concurrent.AbstractFuture.set(AbstractFuture.java:185)
[INFO] [talledLocalContainer] at com.google.common.util.concurrent.Futures$CombinedFuture.setOneValue(Futures.java:1764)
[INFO] [talledLocalContainer] at com.google.common.util.concurrent.Futures$CombinedFuture.access$400(Futures.java:1608)
[INFO] [talledLocalContainer] at com.google.common.util.concurrent.Futures$CombinedFuture$2.run(Futures.java:1686)
[INFO] [talledLocalContainer] at com.google.common.util.concurrent.SettableFuture.set(SettableFuture.java:53)
[INFO] [talledLocalContainer] at com.atlassian.plugin.refimpl.ContainerManager.<init>(ContainerManager.java:308)
[INFO] [talledLocalContainer] at com.atlassian.plugin.refimpl.InitListener.contextInitialized(InitListener.java:19)
[INFO] [talledLocalContainer] at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4760)
[INFO] [talledLocalContainer] at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5184)
[INFO] [talledLocalContainer] at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
[INFO] [talledLocalContainer] at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:724)
[INFO] [talledLocalContainer] at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:700)
[INFO] [talledLocalContainer] at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:714)
[INFO] [talledLocalContainer] at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:919)
[INFO] [talledLocalContainer] at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1704)
[INFO] [talledLocalContainer] at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
[INFO] [talledLocalContainer] at java.util.concurrent.FutureTask.run(FutureTask.java:266)
[INFO] [talledLocalContainer] at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
[INFO] [talledLocalContainer] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
[INFO] [talledLocalContainer] at java.lang.Thread.run(Thread.java:745)
[INFO] [talledLocalContainer] INFO - 14:58:13,940 - com.atlassian.upm.core.log.PluginSettingsAuditLogService - [localhost-startStop-1] - Thu Jun 23 14:58:13 CST 2016 RefImpl: Successfully started the Universal Plugin Manager
[INFO] [talledLocalContainer] WARN - 14:58:13,940 - strumentation.expose.jmx.schedule.JmxInstrumentSchedulerImpl - [localhost-startStop-1] - atlassian-instrumentation-jmx expose scheduler started.
[INFO] [talledLocalContainer] INFO - 14:58:13,941 - com.atlassian.sal.core.upgrade.DefaultPluginUpgradeManager - [localhost-startStop-1] - Running plugin upgrade tasks...
[INFO] [talledLocalContainer] 六月 23, 2016 2:58:14 下午 org.apache.catalina.core.ApplicationContext log
[INFO] [talledLocalContainer] 信息: org.tuckey.web.filters.urlrewrite.UrlRewriteFilter INFO: loaded (conf ok)
[INFO] [talledLocalContainer] 六月 23, 2016 2:58:14 下午 org.apache.catalina.startup.HostConfig deployWAR
[INFO] [talledLocalContainer] 信息: Deployment of web application archive /Users/myUserNamede/atlastutorial/adminUI/target/container/tomcat8x/cargo-refapp-home/webapps/refapp.war has finished in 23,721 ms
[INFO] [talledLocalContainer] 六月 23, 2016 2:58:14 下午 org.apache.catalina.startup.HostConfig deployDirectory
[INFO] [talledLocalContainer] 信息: Deploying web application directory /Users/myUserNamede/atlastutorial/adminUI/target/container/tomcat8x/cargo-refapp-home/webapps/host-manager
[INFO] [talledLocalContainer] 信息: Deployment of web application directory /Users/myUserNamede/atlastutorial/adminUI/target/container/tomcat8x/cargo-refapp-home/webapps/host-manager has finished in 25 ms
[INFO] [talledLocalContainer] 信息: Deploying web application directory /Users/myUserNamede/atlastutorial/adminUI/target/container/tomcat8x/cargo-refapp-home/webapps/manager
[INFO] [talledLocalContainer] 信息: Deployment of web application directory /Users/myUserNamede/atlastutorial/adminUI/target/container/tomcat8x/cargo-refapp-home/webapps/manager has finished in 16 ms
[INFO] [talledLocalContainer] 六月 23, 2016 2:58:14 下午 org.apache.coyote.AbstractProtocol start
[INFO] [talledLocalContainer] 信息: Starting ProtocolHandler ["http-nio-5990"]
[INFO] [talledLocalContainer] 信息: Starting ProtocolHandler ["ajp-nio-8009"]
[INFO] [talledLocalContainer] 六月 23, 2016 2:58:14 下午 org.apache.catalina.startup.Catalina start
[INFO] [talledLocalContainer] 信息: Server startup in 24071 ms
[INFO] [talledLocalContainer] Tomcat 8.x started on port [5990]
[INFO] refapp started successfully in 32s at http://myUserNamedeMacBook-Pro.local:5990/refapp
[INFO] Type Ctrl-D to shutdown gracefully
[INFO] Type Ctrl-C to exit
[INFO] [talledLocalContainer] INFO - 14:58:20,497 - com.atlassian.marketplace.client.MarketplaceClient - [UpmScheduler:thread-2] - GET https://marketplace.atlassian.com/rest/1.0/
[INFO] [talledLocalContainer] INFO - 14:58:21,997 - com.atlassian.upm.analytics.impl.MpacAnalyticsPublisher - [UpmScheduler:thread-2] - MPAC returned error 404 for audit event (updates)
In build plugin section of your pom.xml file
Change
<artifactId>maven-refapp-plugin</artifactId>
to
<artifactId>maven-jira-plugin</artifactId>
and in plugin configuration
<productVersion>${refapp.version}</productVersion>to
<productVersion>${jira.version}</productVersion>add following line after the <productVersion>
<productDataVersion>${jira.version}</productDataVersion>
e..it's amazing. http://myUserNamedeMacBook-Pro.local:5990/refapp has work! opend with chrome it show the page same as what your tutorial shown.
but i remembered it don't work earlier times.
i have edit the bash_profile location at /Users/myUserName/bash.profile . edit the M2_HOME from "/usr/share/java/maven-3.0.3" to "/Applications/Atlassian/atlassian-plugin-sdk-6.2.6/apache-maven-3.2.1" which was created by sdk-installer-6.2.6.dmg.
before i edit bash_profile file http://myUserNamedeMacBook-Pro.local:5990/refapp don't work and now it is working.but the error log still occurred when run "atlas-run" in my terminal.
Is the plugin not working?
run this http://myUserNamedeMacBook-Pro.local:5990/refapp and see if it opens?
