Get projectID for versionID in scriptrunner
Chuck Vanderwist
February 27, 2018 edited
I have a versionID and I want to retrieve the project's ID, name, Key, Lead, Category, etc
I retrieve the projectID with a versionID via http/REST with:
rest/api/2/version/{versionId}
I can then retrieve the other project details from
rest/api/2/project/{projectId}
... How would I go about retrieving the same information from within scriptrunner script, without using http requests?
I've tried using the ComponentAccessor's versionManager like this:
def ProjectManager = ComponentAccessor.projectManager
def VersionManager = ComponentAccessor.versionManager
long version = 23958
def versionObject = VersionManager.getVersion(version)
log.warn(versionObject)
...but I can't figure out how to get the projectID from the version object in this manner.
Joshua Yamdogo @ Adaptavist
February 27, 2018
Charles,
Is this for ScriptRunner for JIRA Server?
If so, you should should be able to call getProjectId() on the Version object.
log.warn(versionObject.projectId)
See https://docs.atlassian.com/software/jira/docs/api/7.8.0/com/atlassian/jira/project/version/Version.html
Chuck Vanderwist
February 28, 2018 edited
Thanks Joshua!
I actually used .getProjectId() on the version object for my final script (putting that into a new variable)
Now I know to keep digging in that api doc :)
February 28, 2018
No problem. If you plan to write a lot of scripts, you might consider following our "Setting up a dev environment guide"
https://scriptrunner.adaptavist.com/latest/jira/DevEnvironment.html#_connecting_intellij_idea_with_the_atlassian_source_code
That functionality makes it a lot easier to see which methods are available for your objects (like Version).
Ignacio Flores May 25, 2021
How can I get "project ids" from a collection of version ids?
Its necessary use for.each ? how I can show a later out the for.each the list with projects ids ?
Register today
