Hi I'm working on a project which involves API calls. I was able to perform the Post api successfully but I'm getting 400 error for the GET request. I have tried so many times but still i'm getting the same error. Any solutions?
My Code
String targetURL = 'https://graph.microsoft.com/v1.0/users/pradeep@avaMigration.onmicrosoft.com'
try {
URL restServiceURL = new URL(targetURL);
HttpURLConnection httpConnection = (HttpURLConnection) restServiceURL.openConnection();
httpConnection.setRequestMethod("GET");
//httpConnection.setRequestProperty("Accept", "application/json");
httpConnection.setRequestProperty("Authorization", "Bearer " + "the token);
if (httpConnection.getResponseCode() != 200) {
throw new RuntimeException("HTTP GET Request Failed with Error code : "
+ httpConnection.getResponseCode());
BufferedReader responseBuffer = new BufferedReader(new InputStreamReader(
(httpConnection.getInputStream())));
String output;
log.debug("Output: \n");
while ((output = responseBuffer.readLine()) != null) {
return output;
httpConnection.disconnect();
} catch (MalformedURLException e) {
e.printStackTrace();
} catch (IOException e) {
This line is plain wrong:
Do you have the token as the variable "token"? If so, then it should be something like:
httpConnection.setRequestProperty("Authorization", "Bearer " + token);
Hi @Pradeep A
From the code you have shared, I noticed an error, i.e.:-
You have missed out on a closed quotation for your String parameter. It should be:-
httpConnection.setRequestProperty("Authorization", "Bearer " + "the token");
I hope this helps to solve your question. :)
Thank you and Kind Regards,
Ram
Did you catch the news at Team ‘25? With Loom, Confluence, Atlassian Intelligence, & even Jira 👀, you won’t have to worry about taking meeting notes again… unless you want to. Join us to explore the beta & discover a new way to boost meeting productivity.
Register today!Online forums and learning are now in one easy-to-use experience.
