i want to know if we can get the assignee date of a jira issue and put it into a script field or something similar with Date type.
Our Business need to know when a jira issue has been assigned to someone while making a jql filter.
Many thanks in advance.
Best Regards,
Wajih
You can create a Date Time picker custom field and put below code to capture the time of assignment into that.
This needs to be added as Script Runner custom listener for the event 'Issue Assigned'
import com.atlassian.jira.issue.ModifiedValue
import java.sql.Timestamp
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
def issue = event.issue as Issue
def datecf1 = customFieldManager.getCustomFieldObject('customfield_xxxxx') //custom field ID
def val = new Timestamp((new Date()).time)
def changeHolder = new DefaultIssueChangeHolder()
datecf1.updateValue(null, issue, new ModifiedValue(issue.getCustomFieldValue(datecf1), val),changeHolder)
You can modify the code if you just want to capture the date only.
HI @Gikku ,
many many thanks for your help it works as a charm.
Do you please have a documentation or seomthing that it can help improving our skills in groovy script runner for jira ?
Thanks a lot.
Wajih
I don't have any documentation link available but usually for such requirements I browse through the Script runner examples within Community or Adaptivist documentations and also refer the Jira API documents for the version.
You can also follow the Youtube videos here
Regards
Gikku
Help us plant more trees
