OK managed to do it via ajs.params.remoteUser, but I get the ID of the user not the name...
OK solved, its ajs.params.userDisplayName
Here is a sample:
<body>
<script type="text/javascript">
AJS.toInit(function(){
alert("ID: " + AJS.params.remoteUser.toUpperCase() + " | UserName: " + AJS.params.userDisplayName + " | PageID: " + AJS.params.pageId);
</script>
</body>
Place this into an HTML macro...
So I was able to use that variable to get this:
var remoteUser = AuthenticatedUserThreadLocal.getUsername();
_paq.push(['setUserId', 'xxx']);
_paq.push(["setCustomVariable", 1, "username", remoteUser, "visit"]);
However, I am at a loss a since I need to acquire username in DN form for the UserID.
It looks like you are trying to write variables rather than read variables...that I haven't tried yet.
That method only works in older versions since the newer versions disable AJS.
var user = AJS.Meta.get("remote-user");
var userdn = AJS.params.userDisplayName;
var userremote = AJS.Meta.get("remote-user");
Here is what I use:
var userFullname = $("#user-menu-link").attr("title");
Your mileage may vary depending on how your Confluence is configured.
