Getting an exception error while using Bulk Clone
Melanie Wu January 12, 2015
I am trying to clone multiple issues in my JIRA project using bulk clone. I followed the steps listed in the documentation, however, when I click "BulkClone", I am getting the error:
Exception: An Exception occurred while cloning the issues corresponding to the specified filter.
What am I doing wrong?
Lars Broden
January 29, 2015
Thanks Matt,
That should be sufficent to Nail the problem.
Will be back shortly after analysis & debugging
Kind Regards
Lars Broden
Lars Broden
February 5, 2015
Great!!
John Kelly February 5, 2015
Sorry for the delay, I wasn't able to test the newest version until just now, but it seems like everything is working.  Thanks!
Lars Broden
January 30, 2015
Great!
Melanie Wu January 30, 2015
VICTORY!
Thanks Lars and everyone else. I did not have access to the logs until just now, but it is fixed and working!
Lars Broden
January 30, 2015
John/Matt
a BulkClone 1.0.15.2 has now been published on the Marketplace that should resolve the issue referring to the earlier error log you sent.
Good luck
Lars Broden
Nicușor Vucescu January 30, 2015
Version 1.0.15.2 will be out soon and it offers support for the above scenario.
Thank you very much for your input and looking forward to receiving feedback on the above error once 1.0.15.2 is installed.
Best,
Nicu
This is not the same error, they are different.
  • first error - line 430
  • second - line 444
The above error occurs because your issue does not have a priority, is that correct?
  • Was that issue result of a csv import where the priority field was not specified?
The current bulk clone has a lot of data validations and it will not succeed in cloning an issue until the issue data is valid.
Best,
Nicu
Lars Broden
January 30, 2015
Ok, were on it, stay tuned..
Lars
John Kelly January 30, 2015
Yes! Downgrading to 1.0.11 allowed me to clone without error
We're still seeing the error on the newest version, here is the trace:
/secure/BulkCloneDetails.jspa [jira.plugins.bulkclone.BulkCloneDetails] An error has occured:
java.lang.NullPointerException
at com.lbcg.jira.plugins.bulkclone.BulkCloneDetails.doExecute(BulkCloneDetails.java:444)
at webwork.action.ActionSupport.execute(ActionSupport.java:165)
at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:88)
at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:39)
at webwork.interceptor.NestedInterceptorChain.proceed(NestedInterceptorChain.java:31) <+5> (ChainedInterceptor.java:16) (DefaultInterceptorChain.java:35) (GenericDispatcher.java:225) (GenericDispatcher.java:154) (JiraWebworkActionDispatcher.java:152)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727) <+2> (ApplicationFilterChain.java:303) (ApplicationFilterChain.java:208)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) <+14> (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (ChainedFilterStepRunner.java:87) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (XContentTypeOptionsNoSniffFilter.java:22) (AbstractHttpFilter.java:31) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (HeaderSanitisingFilter.java:44) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (IteratingFilterChain.java:46) (DelegatingPluginFilter.java:70)
at com.idalko.jira.plugins.igrid.WebResourceIncludeFilter.doFilter(WebResourceIncludeFilter.java:161) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.atlassian.jira.tzdetect.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:39) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.atlassian.jira.baseurl.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:38) <+8> (AbstractHttpFilter.java:31) (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70) (ContextFilter.java:25) (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.atlassian.mywork.client.filter.ServingRequestsFilter.doFilter(ServingRequestsFilter.java:37) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFixupFilter.doFilter(PrettyUrlsSiteMeshFixupFilter.java:36) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.atlassian.prettyurls.filter.PrettyUrlsDispatcherFilter.doFilter(PrettyUrlsDispatcherFilter.java:60) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFilter.doFilter(PrettyUrlsSiteMeshFilter.java:92) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.atlassian.prettyurls.filter.PrettyUrlsMatcherFilter.doFilter(PrettyUrlsMatcherFilter.java:56) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.intenso.jira.contentinjection.filter.ContentInjectionFilter.doFilter(ContentInjectionFilter.java:69) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.atlassian.labs.botkiller.BotKillerFilter.doFilter(BotKillerFilter.java:36) <+23> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (AccessLogFilter.java:103) (AccessLogFilter.java:87) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (XsrfTokenAdditionRequestFilter.java:54) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (SiteMeshFilter.java:181) (SiteMeshFilter.java:85) (SitemeshPageFilter.java:124) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (ChainedFilterStepRunner.java:87) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (IteratingFilterChain.java:46) (DelegatingPluginFilter.java:70)
at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.quisapps.jira.fieldsecurity.filter.FieldSecurityFilter.doFilterChainWithProfiling(FieldSecurityFilter.java:212)
at com.quisapps.jira.fieldsecurity.filter.FieldSecurityFilter.doFilterInterval(FieldSecurityFilter.java:152)
at com.quisapps.jira.fieldsecurity.filter.FieldSecurityFilter.doFilter(FieldSecurityFilter.java:58) <+22> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (SecurityFilter.java:239) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (TrustedApplicationsFilter.java:100) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (BaseLoginFilter.java:172) (JiraLoginFilter.java:70) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (IteratingFilterChain.java:46) (DelegatingPluginFilter.java:70) (OAuthFilter.java:69) (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) <+13> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (ProfilingFilter.java:99) (JIRAProfilingFilter.java:19) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (AbstractJohnsonFilter.java:71) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208)
at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92) <+10> (UrlRewriteFilter.java:394) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (GzipFilter.java:82) (GzipFilter.java:59) (JiraGzipFilter.java:55) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (IteratingFilterChain.java:46) (DelegatingPluginFilter.java:70)
at com.atlassian.analytics.client.filter.JiraAnalyticsFilter.doFilter(JiraAnalyticsFilter.java:41) <+4> (AbstractHttpFilter.java:31) (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) <+40> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (ChainedFilterStepRunner.java:87) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (AbstractCachingFilter.java:33) (AbstractHttpFilter.java:31) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (AbstractEncodingFilter.java:41) (AbstractHttpFilter.java:31) (PathMatchingEncodingFilter.java:49) (AbstractHttpFilter.java:31) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (JiraStartupChecklistFilter.java:79) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (MultipartBoundaryCheckFilter.java:41) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (ChainedFilterStepRunner.java:87) (JiraFirstFilter.java:60) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (StandardWrapperValve.java:220) (StandardContextValve.java:122) (AuthenticatorBase.java:501) (StandardHostValve.java:171) (ErrorReportValve.java:103) (StandardEngineValve.java:116) (AccessLogValve.java:950) (CoyoteAdapter.java:408) (AbstractHttp11Processor.java:1070) (AbstractProtocol.java:611) (JIoEndpoint.java:316)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Unknown Source)
Matt Clemens January 30, 2015
never mind!  I'm not awake yet today.. i had put in a label for the bulk clone and was not thinking and put a space in it.
Lars Broden
January 30, 2015
Can you clone without problems with the 1.0.1.1 release? Lars
Added a comment below, downgrading to 1.0.11 worked.
Lars
Thanks for the update.  Now when running the clone we see the following..
Error
Spaces not allowed in label names or label suffix exceeds max length (50 Characters in total).
Lars Broden
January 29, 2015
Ok Matt we finally nailed the problem that it needs to also cloned unassigned assignees, this has now been handled.
A new version 1.0.15.1 has now been published and this problem should be history
Good Luck
Lars Broden
Matt Clemens January 29, 2015
Wait.. I spoke too soon.. after digging deeper in the logs it does show this..
        at com.lbcg.jira.plugins.bulkclone.BulkCloneDetails.doExecute(BulkCloneDetails.java:430)
        at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61)  <+22> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (SecurityFilter.java:239) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (TrustedApplicationsFilter.java:100) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (BaseLoginFilter.java:172) (JiraLoginFilter.java:70) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (IteratingFilterChain.java:46) (DelegatingPluginFilter.java:70) (OAuthFilter.java:69) (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
        at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)  <+10> (UrlRewriteFilter.java:394) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (GzipFilter.java:88) (GzipFilter.java:59) (JiraGzipFilter.java:55) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (IteratingFilterChain.java:46) (DelegatingPluginFilter.java:70)
        at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61)  <+40> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (ChainedFilterStepRunner.java:87) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (AbstractCachingFilter.java:33) (AbstractHttpFilter.java:31) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (AbstractEncodingFilter.java:41) (AbstractHttpFilter.java:31) (PathMatchingEncodingFilter.java:49) (AbstractHttpFilter.java:31) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (JiraStartupChecklistFilter.java:79) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (MultipartBoundaryCheckFilter.java:41) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (ChainedFilterStepRunner.java:87) (JiraFirstFilter.java:60) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (StandardWrapperValve.java:220) (StandardContextValve.java:122) (AuthenticatorBase.java:610) (StandardHostValve.java:171) (ErrorReportValve.java:103) (StandardEngineValve.java:116) (AccessLogValve.java:950) (CoyoteAdapter.java:408) (AbstractHttp11Processor.java:1070) (AbstractProtocol.java:611) (JIoEndpoint.java:316)
Lars
I installed the new version and re-ran the clone but unfortunately this is all that is logged in atlassian-jira.log.
The web page displays this when it fails..
Error
Exception:An Exception occurred while cloning the issues corresponding to the specified filter.
Lars Broden
January 29, 2015
Hi,There is a BulkClone 1.0.15 out with  more extensive error logging built in.
Please upgrade, rerun and send us the error log at lars.broden@lbconsultinggroup.org
Cheers
Lars Broden
Lars Broden
January 28, 2015
Ok, we Will shortly provide a 1.0.14.1 version with some extended error logging to se exactly what is going on here.
stay tuned...
Lars Broden
Matt Clemens January 28, 2015
I tried clearing the plugin caches and restarting.. still not working.
Trying to bulk clone 450 issues.
we get the exact same error.. and in the JIRA log we see..
/secure/BulkCloneDetails.jspa [jira.plugins.bulkclone.BulkCloneDetails] [Ljava.lang.StackTraceElement;@1c65c54c
Melanie Wu January 28, 2015
Hey Matt,
Still trying to work Lars' suggestion on my end. Will let you guys know!
Melanie
Did Lars suggestion resolve the issue?
Lars Broden
January 12, 2015
Hi, This is most likely a plugin cache error. shutdown your jira server, clear the plugin cache and restart the jira server and It should work.
Also clear your browser cache and reastart the browser
If you still have a problem, I would need portion of the jira log posted which causes the error
Cheers Lars Broden
JIRA v6.3.13
BulkClone v1.0.13
Lars Broden
January 12, 2015
Your JIRA version and BulkClone version?
Help us plant more trees
