Hi we are using jira 5.2 and suddently getting error while creating issue as "Could not load functionProvider class " can some one please help me.
Mangesh
There is not a lot to go on there. Could you give us more of the error in the log (it should at least be telling you which classes are not loading)?
Also, it's often a plugin that has done this - what have you changed recently? Upgrade Jira, new version of any plugins? Changed the workflow to use functions provided by a plugin?
There is litterly nothing in log, we changed the jira workflow but no upgrade to jira or no new plugin.
Hi
we found this log after more research :
" Could not load class 'de.polscheit.jira.workflow.UnsetPlanningDatesFunction'" from install log
The change of workflow implies you have brought in a function that is no longer working. Check you're using the right version of the plugin (Polscheit is probably Frank's Gantt chart plugin, but I'm not 100% sure)
