×as Nic mentions in this thread, the proper way of solving this is:
Since you have such a minor version difference, you could also try out to replace the version numbers in the xml (at your own risk).
Matthias.
Can you please provide me the link to download the JIRA having 713000 build number.
Depending on the type of Jira you have installed, you can download it from these links:
I believe, 713000 should be Jira 7.13.0. So you can search for this release on the corresponding page.
Matthias.
you are trying to import project data from different version of jira, source and destination Jira server version should be same
