GitHub hooks not created automatically for new repository
Ankur
I am using JIRA 8.5.3 with Jira DVCS Connector Plugin - 5.2.6.
I created the DVCS connection with GitHub Enterprise. When DVCS connector is added in JIRA, it created hooks in GitHub for each repository. The hook got created with wrong payload url though (see known issue). However I updated the url manually and the connection works fine thereafter.
I am facing another problem now. When I create a new repository now in GitHub, the expectation is that the jira hook will be created automatically under that repository. However, this is not happening. "Automatically sync all repositories" option was always enabled in JIRA DVCS configuration.
The workaround is to login to JIRA and then do a manual 'Refresh repositories' but then this will have to be done whenever a new repository gets created in GitHub.
Is this another known issue with Jira DVCS Connector Plugin - 5.2.6 ?
Chris Terry
July 14, 2021
Hello Ankur,
Thanks for raising awareness about this topic. We have an open suggestion for this which you can follow along at JRASERVER-68876: Add GitHub webhooks during autodiscovery.
I encourage you to Vote on the feature request to increase its popularity and Watch to stay informed of progress going forward. For more details on how Atlassian prioritizes new suggestions, please refer to the Implementation of New Features Policy.
You can also see what the Jira team is currently working on at our new public dashboards!
Chris
