Global Permissions for Adminstrator but Restricted Project Access?
Kyle
Is there a world in Jira Data Center where someone can hold Global Configuration Permissions but have only administrative access to a select handful of projects?
We are merging an ITSM Jira instance and related projects (i.e. A,B,C) and a Construction Work Order instance and related projects (i.e. D,E,F) into one Data Center.
Our new Data Center will now host projects A-F.
As the global administrator for our current Construction Work Order instance and projects D,E,F, I would like to be able to still make custom fields, new issue types, and manage App configurations when our instances merge into one data center. However, I should not have access to ITSM Jira Projects A, B, C.
Is this possible?
Nic Brough -Adaptavist-
September 13, 2021
No, there's no way to do this.  An administrator's access is not limited to projects (it can't be - most of what they will be administrating are not locked to projects, but global objects)
Kyle
I don't like the answer for our business case. But I will accept it ;)
