Added the mandatory fields as per the selected issue type for the project.
This is the error response:
Wed Dec 20 12:32:11 IST 2017 Unable to add testcase ending at rowNumber - 1. Error:Unexpected response code: 400
{"errorMessages":[],"errors":{"customfield_12200":"Environment/s is required."}}
I gave Environment/s in the excel but still throwing same error. Added the screenshot for reference.
What is the field type of 'Environment/s'? Please check whether the 'QA' value does exists in the 'Environment/s' field values or not.
Is there any compatibilty with java version?? Which version do I need to install for this?
If you are using JIRA 7.x version, better to use latest java 1.8 kit. Otherwise let us know what version of Jira you are using.
