Groovy: How to update single option custom field?
Alexander Yordanov
February 12, 2019 edited
I'm writing a code that depending on the Request Type from the portal it should update a custom field called "IT Change Type". The custom field has the options: "Normal", "Urgent" and "Retro". I'm getting the option for the custom field, and the custom field but it still doesn't update it.
import com.atlassian.jira.issue.fields.CustomField;
import com.atlassian.jira.issue.ModifiedValue
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
MutableIssue mutableIssue = (MutableIssue) issue;
log.info("issue: " + mutableIssue.toString());
def reqType = ComponentAccessor.customFieldManager.getCustomFieldObjectByName('Customer Request Type');
def reqTypeVal = mutableIssue.getCustomFieldValue(reqType).getValue();
log.info("Issue type: " + reqTypeVal);
def changeTypeId = 14430;
def customFieldManager = ComponentAccessor.getCustomFieldManager();
def CustomField changeType = ComponentAccessor.getCustomFieldManager().getCustomFieldObject(changeTypeId);
def fieldConfig = changeType.getRelevantConfig(issue);
switch (reqTypeVal) {
case "itcm/e89992e0-cbf1-4208-ad24-e8ea100f2c33":
def value = ComponentAccessor.optionsManager.getOptions(fieldConfig)?.find { it.toString() == 'Normal' };
log.info("field option: " + value.toString());
log.info("field name: " + changeType.toString());
mutableIssue.setCustomFieldValue(changeType, value);
break;
case "itcm/3b6cb133-0971-48c4-8b53-d5a49af828ca":
def value = ComponentAccessor.optionsManager.getOptions(fieldConfig)?.find { it.toString() == 'Urgent' };
break;
case "itcm/74b2e0f8-33ef-4a14-a905-f1ef7460d6ae":
def value = ComponentAccessor.optionsManager.getOptions(fieldConfig)?.find { it.toString() == 'Retro' };
break;
Sample log from the code:
2019-02-12 06:22:48,441 [http-nio-8080-exec-4] | issue: ITCM-66
2019-02-12 06:22:48,443 [http-nio-8080-exec-4] | Issue type: itcm/74b2e0f8-33ef-4a14-a905-f1ef7460d6ae
2019-02-12 06:22:48,444 [http-nio-8080-exec-4] | field option: Retro
2019-02-12 06:22:48,444 [http-nio-8080-exec-4] | field name: IT Change Type
But then the field in the issue is not updated even tho there are no visible errors.
Any idea?
Alex
evzensx February 12, 2019
You just set value, but not save it. Try something like that in your switch\case construction:
def issueService = ComponentAccessor.getIssueService()
def issueInputParameters = issueService.newIssueInputParameters()
def loggedInUser = ComponentAccessor.jiraAuthenticationContext.loggedInUser
def validationResult = issueService.validateUpdate(loggedInUser, issue.id, issueInputParameters)
if (change) {
log.warn "Value changed from ${change.oldstring} to ${change.newstring}"
//commentManager.create(issue,user,comment,true)
if (validationResult.isValid()) {
issueManager.updateIssue(loggedInUser, issue, EventDispatchOption.ISSUE_UPDATED, false)
else {
log.warn event?.getChangeLog()?.getRelated("ChildChangeItem")?.find {it.field}
Alexander Yordanov
Hey, thanks that helped a lot! After the switch/case I added
ComponentAccessor.getIssueManager().updateIssue(loggedInUser, mutableIssue, EventDispatchOption.DO_NOT_DISPATCH, false);
And it worked!
Alex
Like evzensx likes this
