I'm getting groovy records from SQL Table or Function. Example;
String subeKodu = get_sube_kodu_bul(matcher[0][1])
private String get_sube_kodu_bul(String subeAdi) { def sql = Sql.newInstance("jdbc:jtds:sqlserver://10.xx.xx.xx:1433/DBNAME", "usrname","pass", "net.sourceforge.jtds.jdbc.Driver") subeAdi = subeAdi.trim() def row = sql.firstRow("SELECT TOP 1 SUBE_KODU FROM TABLENAME WHERE SUBE_ADI= '${subeAdi}'") if (row != null) return (String)row.SUBE_KODU else return "" }
But I am faced with the following error;
WARNING: In Groovy SQL please do not use quotes around dynamic expressions (which start with $) as this means we cannot use a JDBC PreparedStatement and so is a security hole. Groovy has worked around your mistake but the security hole is still there. The expression so far is: SELECT TOP 1 YETKILI FROM TABLENAME WHERE SUBE_ADI = '?'
Help please, thank you
Connection change and solved.
Try the following:
def row = sql.firstRow("SELECT TOP 1 SUBE_KODU FROM TABLENAME WHERE SUBE_ADI= ?",[subeAdi])
Hi Alexey, the same error
