Groovy Script Runner issue
Roy Chapman
We have created a workflow that relies heavily on the send custom email post function functionality that script runner provides.
In the To Issue Fields: I specify a custom field which is a multi-user selector field and get the below error no matter if I specify one user or multiple.
v3.0.7 doesn't fix it.
Below the stack dump generated in logs when the post function is executed.
Exception in thread "Thread-71" java.lang.NullPointerException: Cannot invoke method split() on null object
        at org.codehaus.groovy.runtime.NullObject.invokeMethod(NullObject.java:88)
        at org.codehaus.groovy.runtime.callsite.PogoMetaClassSite.call(PogoMetaClassSite.java:45)
        at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:45)
        at org.codehaus.groovy.runtime.callsite.NullCallSite.call(NullCallSite.java:32)
        at java_lang_String$split$6.call(Unknown Source)
        at com.onresolve.scriptrunner.canned.jira.workflow.postfunctions.SendCustomEmail.getAddressesFromFields(SendCustomEmail.groovy:529)
        at com.onresolve.scriptrunner.canned.jira.workflow.postfunctions.SendCustomEmail$getAddressesFromFields$3.callCurrent(Unknown Source)
        at com.onresolve.scriptrunner.canned.jira.workflow.postfunctions.SendCustomEmail.getAllToAddresses(SendCustomEmail.groovy:460)
        at com.onresolve.scriptrunner.canned.jira.workflow.postfunctions.SendCustomEmail$getAllToAddresses$2.callCurrent(Unknown Source)
        at com.onresolve.scriptrunner.canned.jira.workflow.postfunctions.SendCustomEmail.constructMail(SendCustomEmail.groovy:298)
        at com.onresolve.scriptrunner.canned.jira.workflow.postfunctions.SendCustomEmail$constructMail.callCurrent(Unknown Source)
        at com.onresolve.scriptrunner.canned.jira.workflow.postfunctions.SendCustomEmail.sendMail(SendCustomEmail.groovy:317)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
        at java.lang.reflect.Method.invoke(Unknown Source)
        at org.codehaus.groovy.reflection.CachedMethod.invoke(CachedMethod.java:90)
        at groovy.lang.MetaMethod.doMethodInvoke(MetaMethod.java:324)
        at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:1207)
        at org.codehaus.groovy.runtime.ScriptBytecodeAdapter.invokeMethodOnCurrentN(ScriptBytecodeAdapter.java:78)
        at com.onresolve.scriptrunner.canned.jira.workflow.postfunctions.SendCustomEmail.this$dist$invoke$1(SendCustomEmail.groovy)
        at com.onresolve.scriptrunner.canned.jira.workflow.postfunctions.SendCustomEmail$1.methodMissing(SendCustomEmail.groovy)
        at groovy.lang.MetaClassImpl.invokeMissingMethod(MetaClassImpl.java:933)
        at groovy.lang.MetaClassImpl.invokePropertyOrMissing(MetaClassImpl.java:1256)
        at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:1209)
        at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:1016)
        at org.codehaus.groovy.runtime.callsite.PogoMetaClassSite.callCurrent(PogoMetaClassSite.java:66)
        at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:141)
        at com.onresolve.scriptrunner.canned.jira.workflow.postfunctions.SendCustomEmail$1.run(SendCustomEmail.groovy:354)
        at java.lang.Thread.run(Unknown Source)
Peter Bengov
December 15, 2014
Are you sure the variable you using the split() function on is mandatory? Looks like the value is empty, which disables ability to run split() on your variable.
Radu Dumitriu
December 15, 2014
... but wait, there's no close :) within the new Answers
Radu Dumitriu
December 15, 2014
Register today
