is it possible to run a script when the "Create a new issue or add a comment to an existing issue" mail handler add a comment to an existing issue?
Dominik
You could try: https://jamieechlin.atlassian.net/browse/GRV-13
I don't think I got round to integrating that code.
Failing that you could add listeners, but I don't know how to distinguish events caused by mail handlers vs standard events. You could try checking transientVars and see if there is anything in there.
it's a bit of a hack but i've been using this to see if an issue was created with the mail handler: if ( Thread.currentThread().getStackTrace().grep(~/com.atlassian.jira.plugins.mail.handlers.CreateIssueHandler.*/) ) { // created via mail handler } else { // created some other way }
Thanks, i will try https://jamieechlin.atlassian.net/browse/GRV-13
is there still a way to run a script when a comment is generally added? Regardless of where the comment is coming from ... mail handler, transition screens, ...
Yeah, use a listener. See https://jamieechlin.atlassian.net/wiki/display/GRV/Listeners
