×I have a JIRA custom field that is populated based on the value of another custom field. If the first field is null, I want the field I am populating to also be null. What is the proper syntax for "is null" in the first line shown below? It works without that line but will default to "Low". I need it to default to null or actually do nothing.
Thank you,
Jeannette
if ( issue.getCustomFieldValue(customField_name) = "")
return null
else if ( issue.getCustomFieldValue(customField_name) >= 6)
return "High"
else if ( issue.getCustomFieldValue(customField_name) <= 2)
return "Low"
else
return "Med"
Hi jnet,
I'm assuming that your source custom field is a Numeric Custom field and that you're using a scripted field.
In this scenario the correct code should be :
import com.atlassian.jira.issue.Issue; import com.atlassian.jira.issue.fields.CustomField; import com.atlassian.jira.component.ComponentAccessor; import com.atlassian.jira.issue.CustomFieldManager; CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager(); Issue issue = issue; CustomField sourceCF = customFieldManager.getCustomFieldObjectByName("Source Field"); Integer sourceValue = issue.getCustomFieldValue(sourceCF); if(sourceValue!=null){ if(sourceValue>=6) return "High"; else if (sourceValue<=2) return "Low"; else return "Med"; } return "null";
Please, keep in mind that if the source value is not populated this script will display "null". If you want to not show this field if null please, write return "" instead of return "null' at the last script row.
Moreover, you need to change "Source Field" with the correct name of your custom field.
I hope this helps.
Fabio
Thank you, this worked perfectly! I now have a follow up question regarding my numeric custom field. please see https://answers.atlassian.com/questions/278603/which-custom-field-type-can-be-used-as-an-input-for-a-numeric-calculation#
I'm not exactly sure what you are trying to do but in the other answer, 'return "null"' is almost certainly not what you want. Instead just: return null
Regarding proper syntax for is null - generally you just want to use groovy truth, and not distinguish between nulls and empty strings.
So I would just use:
if (! sourceValue) { ... }
