I am trying to setup a fast-track transition using the Script Runner plugin. It appears, however, that I cannot access nor modify variables declared before the loops inside the loops. Similarly, I cannot access variables from inside the loop outside of it. Does anyone have any suggestions?
My current code:
subtasksclosed = true
parent = issue
if(issue.isSubTask()){
parent = issue.getParentObject()
Outer:
for (subtask in parent.getSubTaskObjects()){
if (subtask.statusObject.name != "Closed"){
subtasksclosed = false
break Outer
} else if(issue.subTasks.size > 0) {
Outer2:
for (subtask in issue.getSubTaskObjects()){
break Outer2
subtasksclosed == true && parent.statusObject.id == "10020"
Maybe you could try this code, so you don't have to access variables from "the other side":
parent = issue
subtasksclosed = parent.subTaskObjects.any{it.statusObject.name != "Closed"}
subtasksclosed && parent.statusObject.id == "10020"Henning
Yes, write it using any(<closure>). I don't see any obvious reason why the original code is not working, but if you do it like Henning suggests it will be a lot more succinct and more obvious if there is a bug.
Any error messages in the log?
I think you should try to add a lot of
log.error issue.dump()
log.error parent.dump()
lines to your source to get the point where the scripts don't behave like expected.
Interestingly, if I run this through the built in "Condition Tester" in the plugin, it works fine.
