Hi All,
I have written the below script for creating the issue in Jira, but getting issue created.
import com.atlassian.jira.bc.issue.IssueService.CreateValidationResult
import com.atlassian.jira.bc.issue.IssueService.IssueResult
import com.atlassian.jira.issue.IssueManager
import org.apache.log4j.Category
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.*
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.bc.issue.IssueService;
import com.atlassian.jira.bc.issue.IssueService.CreateValidationResult;
import com.atlassian.jira.bc.issue.IssueService.IssueResult;
import com.atlassian.jira.issue.CustomFieldManager;
import com.atlassian.jira.issue.fields.CustomField;
Collection<CustomField> customFields = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectsByName("customFieldId=18229");
println(customFields);
for (CustomField customField : customFields) {
if (customField.getValue(issue).toString().equals("Yes")) {
//customField=Yes, create issue
IssueService issueService = ComponentAccessor.getIssueService();
println(issueService);
CreateValidationResult createValidationResult = issueService.validateCreate(currentUser, issueInputParameters);
if (createValidationResult.isValid())
IssueResult createResult = issueService.create(currentUser, createValidationResult);
if (!createResult.isValid())
println("issue created");
Any help/Suggestion would be appreciated.
Dileep Kumar
Why are you creating a script for it? what's your use-case as it's generally supported by script runner to create an issue at workflow post-function.
Hi Tarun,
Thanks for the help !!
I want the script which will create the issue/sub-task based on given Custom Field.
Suppose if CodeReview(Custom Field) is yes then issue/sub-task should be created.
After this created issue, i want it to link with another issue.
This is my overall requirement.
Can you please help me with the groovy script for above requirement ?
Dileep Kumar
If you have script runner plugin then it's a built-in post function to create a sub-task or to create an issue. You don't have to write a script for it.
And you can easily add a condition before the execution of the post-function, and if the condition is true only then the post-function will be executed.
Hi Tarun,
I will check it, if any issue will let you know.
Dileep Kumar
Hi Tarun,
Yes, you are right. The feature is available, but i need to automate this feature by using custom script. So i want the groovy script.
If you can help, it would be great !!
Dileep Kumar
