Groovy Script
JIRA Team Mailbox March 14, 2016
I have a groovy script which updates a Group Custom Field value, but when i run the options will get null,
import com.atlassian.jira.ComponentManager;
import com.atlassian.jira.issue.fields.CustomField;
import com.atlassian.jira.issue.CustomFieldManager;
import com.atlassian.jira.issue.customfields.option.Option
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
import com.atlassian.jira.issue.ModifiedValue
import com.atlassian.jira.issue.customfields.option.Options
import org.apache.log4j.Category
import com.atlassian.jira.issue.customfields.manager.OptionsManager
def Category log = Category.getInstance("com.onresolve.jira.groovy")
log.setLevel(org.apache.log4j.Level.DEBUG)
MutableIssue issue = issue
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager()
CustomField essTeam = customFieldManager.getCustomFieldObjectByName("ESS Team")
OptionsManager optionsManager = ComponentManager.getComponentInstanceOfType(OptionsManager.class)
log.debug "Starting"
if(ComponentManager.getInstance().getUserUtil().getGroupNamesForUser(issue.reporterId).contains("ESS Team")){
        OptionsManager optManager = ComponentAccessor.getOptionsManager();
        Options options = optManager.getOptions(essTeam.getRelevantConfig(issue));
        Option newOption = options.getOptionById(5);
        ModifiedValue mVal = new ModifiedValue(issue.getCustomFieldValue(essTeam ), newOption );
        essTeam.updateValue(null, issue, mVal, new DefaultIssueChangeHolder());
        log.debug "Team is " + options
} else {
What is the issue, issue is not updating as well
Aleks Yenin (Polontech)
March 14, 2016
Is your code a postfunction or just running from a scriprunner?
Retrieving issue this way
is only acceptable while writing a postfunction.
While running script from a scriptrunner you should define iisue by your own, e.g.
MutableIssue issue = ComponentAccessor.getIssueManager().getIssueByCurrentKey("AP-10");
//Replace key "AP-10" with issue key you need.
kanchana wijerathna
thanks problem resolved
atlassian, social impact bingo, may it forward, atlassian foundation, community engagement, atlassian community events, atlassian learning, social impact challenge, volunteering, community kudos, atlassian social impact, atlassian community
Come one, come all!
Hey everyone! Are you ready to make a difference? Join the Atlassian Social Impact Bingo event! ❌⭕
Play Bingo! 🙋🏻‍♂️
