Groovy : Set Remaining time on subtask to 0
Thibauld Leprince February 11, 2014
i am recently using the script runner plugin to autoclose suktasks when the parent issue is closed.
Can you tell me the lines to add to force the "Remaning Time" on subtasks to 0 at the same time ?
Thank you.
Henning Tietgens
March 3, 2014
You can try this.
import com.atlassian.jira.bc.issue.IssueService
import com.atlassian.jira.config.SubTaskManager
import com.atlassian.jira.issue.IssueInputParameters
import org.apache.log4j.Category
import static org.apache.log4j.Level.DEBUG
log = Category.getInstance("com.onresolve.jira.groovy.AutoCloseChildIssues")
log.setLevel(DEBUG)
log.debug "debug statements"
IssueService issueService = ComponentAccessor.getIssueService()
SubTaskManager subTaskManager = ComponentAccessor.getSubTaskManager();
if (subTaskManager.subTasksEnabled) {
    MutableIssue issue = issue  // this is only for the IDE
    log.debug ("issue.statusObject.name: " + issue.statusObject.name)
    def currentUser = ComponentAccessor.getUserUtil().getUser("muleuser")
    issue.getSubTaskObjects().each { subtask ->
        IssueInputParameters issueInputParameters = issueService.newIssueInputParameters();
        issueInputParameters.setRemainingEstimate(0L);
        issueInputParameters.setComment("*Réouverte*, car la demande mère a été réouverte.")
        IssueService.TransitionValidationResult transitionValidationResult = issueService.validateTransition(currentUser, subtask.id, 3, issueInputParameters);
        if (transitionValidationResult.isValid()){
            IssueService.IssueResult transitionResult = issueService.transition(currentUser, transitionValidationResult);
            if (!transitionResult.isValid()) {
                transitionResult.errorCollection.errorMessages.each {log.error "Error Message: $it"}
                transitionResult.errorCollection.errors.each {log.error "Error: $it"}
                transitionResult.errorCollection.reasons.each {log.error "Reason: $it"}
        } else {
            transitionValidationResult.errorCollection.errorMessages.each {log.error "Error Message: $it"}
            transitionValidationResult.errorCollection.errors.each {log.error "Error: $it"}
            transitionValidationResult.errorCollection.reasons.each {log.error "Reason: $it"}
There is a nice documentation on how to use the issueService. If it doesn't work there could be a problem with the transition screen. Take a look here, especially setSkipScreenCheck().
Thibauld Leprince March 3, 2014
You are really Good, it works fine.
Another question : if I want set the estimate to 2h for example ?
I wrote setRemainingEstimate(2h) but i doesnt work
it doesnt work
Henning Tietgens
March 3, 2014
Try setRemainingEstimate('2h')
Henning Tietgens
March 4, 2014
You have to make sure you're using a String as parameter, than it should work like documented here. Could you enter 2h manually while entering an estimate?
If it doesn't work you could calculate a long of 2h in your timetracking default units ( APKeys.JIRA_TIMETRACKING_DEFAULT_UNIT) and use this as parameter.
Thibauld Leprince March 4, 2014
Yes, i can write 2h in the field "remaining estimate".
I also try issueInputParameters.setRemainingEstimate(1100L);
but no result
Henning Tietgens
March 4, 2014
Mmh. Setting to 0 works but not to any other value? What did you get if you call issueInputParameters.getRemainingEstimate() after setting the remaining estimate (before the transition)?
log.error "getRemainingEstimate(): ${issueInputParameters.getRemainingEstimate()}"
Are there any other errors in the log?
i found this error :
2014-03-05 13:42:34,087 ajp-bio-8009-exec-31 ERROR leprince.t 821x55358x1 1v714k4 10.253.114.5 /secure/WorkflowUIDispatcher.jspa [atlassian.event.internal.AsynchronousAbleEventDispatcher] There was an exception thrown trying to dispatch event 'com.atlassian.jira.event.issue.IssueEvent@122580a1[issue=PROJWMS-16227,comment=<null>,worklog=<null>,changelog=[GenericEntity:ChangeGroup][id,3359167][author,leprince.t][created,2014-03-05 13:42:24.05][issue,420304],eventTypeId=5,sendMail=true,params={eventsource=workflow, baseurl=https://jira-app-rec-03.stef.com/jira},subtasksUpdated=false]' from the invoker 'SingleParameterMethodListenerInvoker{method=public void com.stef.jira.plugin.listener.JiraIssueListener.onIssueEvent(com.atlassian.jira.event.issue.IssueEvent), listener=com.stef.jira.plugin.listener.JiraIssueListener@2eedaaf4}'.
java.lang.RuntimeException: java.lang.StackOverflowError
Henning Tietgens
March 4, 2014
Do you have any recursion in your code? Could you post the complete stack trace?
(sample catalina.out.txt) contains all lines after the error line i sent before
Henning Tietgens
March 5, 2014
There is a recursion in this code part:
at com.stef.jira.plugin.business.IssueEventFactory.buildCollectionIssueImpl(IssueEventFactory.java:276)
	at com.stef.jira.plugin.business.IssueEventFactory.buildIssueImpl(IssueEventFactory.java:79)
	at com.stef.jira.plugin.business.IssueEventFactory.buildIssueImpl(IssueEventFactory.java:78)
The numbers at the end are the line numbers in the source file. Maybe you should add some debug output to these lines to see why your code is calling itself over and over again. This leads to the stack overflow.
Thibauld Leprince March 5, 2014
Ok thanks i will check that. we keep in touch
Thibauld Leprince March 12, 2014
I tried on another jira instance, but it still doesnt work
Henning Tietgens
March 12, 2014
Any errors in the log?
Stefano Rosario Aruta
February 6, 2019 edited
hi dude, i need your help, i want to changes status on every sub-task in a main issue. I make this code but it doen't work. Can you help me??
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.config.SubTaskManager;
import com.atlassian.jira.issue.Issue;
import com.atlassian.jira.issue.AttachmentManager
import com.atlassian.jira.issue.attachment.Attachment;
import com.atlassian.jira.issue.IssueFactory;
import com.atlassian.jira.issue.IssueManager;
import com.atlassian.jira.issue.MutableIssue;
Issue parentIssue = issue
def currentUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser();
if (issue.getIssueType().getName() != "Sub-task") {
if (parentIssue.getSubTaskObjects().size()>0) {
for(int o = 0; parentIssue.getSubTaskObjects().size() > o; o++) {
if(!parentIssue.getSubTaskObjects()[o].getStatus().equals("DONE")) {
//TransitionOptions traOpt = issue;
// validateTransition(ApplicationUser user, Long issueId, int actionId, IssueInputParameters issueInputParameters, TransitionOptions transitionOptions)
IssueService.TransitionValidationResult transitionValidationResult = issueService.validateTransition(currentUser, parentIssue.getSubTaskObjects()[o].getId(), 3 as Integer, issueInputParameters);
//IssueService.TransitionValidationResult transitionValidationResult = issueService.validateTransition(currentUser, parentIssue.getSubTaskObjects()[o].getId(), 3,"10001", 5 as Integer, issueInputParameters, );
Henning Tietgens
February 6, 2019
Hi Stefano,
you're only validating the transition, you have to do it if the validation result is valid.
def issueService = ComponentAccessor.getIssueService()
if (!parentIssue.isSubTask()) {
parentIssue.subTaskObjects.each{ subtask ->
if (subtask.status.name != "DONE") {
def issueInputParameters = issueService.newIssueInputParameters()
def transitionValidationResult = issueService.validateTransition(currentUser, subtask.id, 3 as Integer, issueInputParameters)
if (transitionValidationResult?.isValid()) {
} else {
def text = "Transition failed. "
transitionValidationResult?.errorCollection?.errorMessages?.each { text += "Error Message: $it\r\n" }
transitionValidationResult?.errorCollection?.errors?.each { text += "Error: $it\r\n" }
transitionValidationResult?.errorCollection?.reasons?.each { text += "Reason: $it\r\n" }
log?.error(text)
Best regards,
Henning
i copy and paste this scritp on my post function but it dosen't work
Henning Tietgens
February 6, 2019
Is the status name correct? Maybe it's "Done"?
the condition is if the sub-task is not DONE  run this code to set sub-task done
Henning Tietgens
February 6, 2019
Yes, that‘s correct. But it‘s a difference if the status name is DONE or Done. Case matters.
Henning Tietgens
February 6, 2019
Take a look into the status list in administration to see the correct case.
The problem is that script doesn't run
Annotazione 2019-02-06 140200.png i don't know it doesn't run
Henning Tietgens
February 6, 2019
Did you changed
to
if (subtask.status.name != "Done") {
But this doesn't explain why the postfunction has not run yet. Did you publish the workflow?
ure dude look the code:
import com.onresolve.scriptrunner.runner.util.UserMessageUtil
UserMessageUtil.success("script is run");
UserMessageUtil.success("we are in the cicle");
UserMessageUtil.success("we are on the condition - if (subtask.status.name != Done)");
issueInputParameters.setComment("TESTETSTESTTESTET.")
UserMessageUtil.success("insane - if (transitionValidationResult?.isValid())");
} else {
log?.error(text)
Henning Tietgens
February 6, 2019
And, do you see any of the messages?
ok i fix that, now the script run, but it worked also if the sub-task is on some status where is connected with a transaction DONE, i need that status change always
Henning Tietgens
February 6, 2019
You have to take care that from every possible status of the subtask workflow (every status not "Done") there is the transition with ID 3 to status Done. If this is not the case add a global transition to Done and use the ID of this transition in your post function script.
i dont know how to use issueService and issueInputParameters.setRemainingEstimate()
Thibauld Leprince February 26, 2014
Hi Henning and Julian,
Many thanks for your asnwer.
Henning, here is my script, can you help me to apply what you said ?
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.issue.IssueService
import com.atlassian.jira.issue.comments.CommentManager
import com.opensymphony.workflow.WorkflowContext
import com.atlassian.jira.workflow.WorkflowTransitionUtil;
import com.atlassian.jira.workflow.WorkflowTransitionUtilImpl;
import com.atlassian.jira.util.JiraUtils;
def Category log = Category.getInstance("com.onresolve.jira.groovy.PostFunction")
log.setLevel(org.apache.log4j.Level.DEBUG)
String currentUser = ComponentManager.getInstance().getUserUtil().getUser("muleuser").getName()
WorkflowTransitionUtil workflowTransitionUtil = ( WorkflowTransitionUtil ) JiraUtils.loadComponent( WorkflowTransitionUtilImpl.class );
SubTaskManager subTaskManager = ComponentManager.getInstance().getSubTaskManager();
Collection subTasks = issue.getSubTaskObjects()
if (subTaskManager.subTasksEnabled && !subTasks.empty) {
    subTasks.each {
        workflowTransitionUtil.setIssue(it);
        workflowTransitionUtil.setUsername(currentUser);
        workflowTransitionUtil.setAction (3)    // 3 == REOPEN ISSUE
	 issueInputParameters.setRemainingEstimate(3)
        // Add a comment so people have a clue why the child has been closed
        CommentManager commentManager = (CommentManager) ComponentManager.getComponentInstanceOfType(CommentManager.class);
        String comment = "*Réouverte*, car la demande mère a été réouverte.";
        commentManager.create(it, currentUser, comment, true);
        // validate and transition issue
        workflowTransitionUtil.validate();
        workflowTransitionUtil.progress();
JulianA
February 24, 2014
I had created a simliar script for this a few months ago. Maybe this can help you.
Usage: Create a JQL-Query that matchs the subtasks, you want to edit. Copy that query
Replace ("INSERT HERE YOUR JQL QUERY") with the created Query.
Run the script
import com.atlassian.jira.issue.fields.CustomField;
import com.atlassian.jira.bc.JiraServiceContextImpl;
import com.atlassian.jira.bc.filter.SearchRequestService;
import com.atlassian.jira.bc.issue.search.SearchService;
import com.atlassian.jira.issue.search.SearchRequest;
import com.atlassian.jira.issue.search.SearchResults;
import com.atlassian.jira.user.ApplicationUser;
import com.atlassian.jira.web.bean.PagerFilter;
import com.atlassian.query.Query;
SearchResults getissuesByJQL(String jql) throws Exception
        SearchService serchService = ComponentAccessor.getComponentOfType(SearchService.class);
        SearchService.ParseResult parseResult = serchService.parseQuery(ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser(), jql);
        if (!parseResult.isValid())
            throw new Exception("jql is not valid. jql was "+jql);
        Query query = parseResult.getQuery();
           SearchResults sr = serchService.search(ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser(), query, PagerFilter.getUnlimitedFilter());
            return sr;
void setEstimateToNull(String key) {
IssueManager im = ComponentAccessor.getIssueManager();
        MutableIssue issue = im.getIssueObject(key);
        issue.setEstimate(0L);
        issue.store();
for (Issue issue : getissuesByJQL("INSERT HERE YOUR JQL QUERY").getIssues())
    setEstimateToNull(issue.getKey());
Thibauld Leprince February 24, 2014
any idea ?
Henning Tietgens
February 24, 2014
Use issueService and issueInputParameters.setRemainingEstimate()
Get Certified! ✍️
