Hi Community,
I am trying to fill in Insight object(s) custom field, which is configured as multiple.
Here is the code:
if (members != null)
for (item in members)
def userInsightField = customFieldManager.getCustomFieldObject("customfield_11525") // TSO members (Insight)
Class iqlFacadeClass = ComponentAccessor.getPluginAccessor().getClassLoader().findClass("com.riadalabs.jira.plugins.insight.channel.external.api.facade.IQLFacade")
def iqlFacade = ComponentAccessor.getOSGiComponentInstanceOfType(iqlFacadeClass)
def member = iqlFacade.findObjectsByIQLAndSchema(3,"\"User Jira Key\" = " + item.key) // Schema 3 = Customer Directory
if (issue.getCustomFieldValue(userInsightField) == null)
{userInsightField.updateValue(null, issue, new ModifiedValue(issue.getCustomFieldValue(userInsightField), member), changeHolder)}
else
{userInsightField.updateValue(null, issue, new ModifiedValue(issue.getCustomFieldValue(userInsightField), issue.getCustomFieldValue(userInsightField) + member), changeHolder)}
//return issue.getCustomFieldValue(userInsightField)
In members, there is an ArrayList of DelegatingApplicationUser
In the return section, I am getting two objects
When executed in post function, only one object is in the field.
Was search for solution for hours, but no success, please, help me out :-)
hi @Tomáš Vrabec as @PD Sheehan suggested you have to use issue.setCustomFieldValue method otherwise it is still NULL when the code is in second, third... loop. It could be
def emails = ['alex.hrabal@metrostavfake.cz', 'frantisek.silny@cetinfake.cz']
for(def item in emails){
def member = iqlFacade.findObjectsByIQLAndSchema(1,"\"Email\" = " + item)
if (issue.getCustomFieldValue(userInsightField) == null) {
issue.setCustomFieldValue(userInsightField, member) // you have to invoke this, otherwise issue.getCustomFieldValue is still null
log.error("null:"+item)
} else {
log.error("not null:"+item)
def oldValue = issue.getCustomFieldValue(userInsightField)
def newValue = oldValue + member
issue.setCustomFieldValue(userInsightField, newValue)
userInsightField.updateValue(null, issue, new ModifiedValue(oldValue, newValue), changeHolder)
But I would try to optimize it and not to set the field with value by value but you should create collection of Insight objects and set it at once. In my case:
def insightObjects = []
if(member){
member = member.get(0)
insightObjects.add(member)
def newValue = oldValue!=null ? new ArrayList(oldValue):[]
insightObjects.each{newValue.add(it)}
Ahoj @Martin Bayer [MoroSystems, s.r.o.]
My final version looks like this:
for(item in members)
if(member)
But yes, it does work! Thanks for the tip with oldValue and newValue, this is exactly what I was looking for! Kudos and accepted answer for you!
I'm not a fan of the customFieldObject.updateValue() method in general because I don't think it will appear in the issue history.
But in your specific case, I would guess that the value you are setting with this low-level api is being updated by the temporary issue object values (which are not updated after you update the custom field value) that the postfunction is holding in memory.
Instead, I would recommend you use the issue.setCustomFieldValue() or issueInputParameters.addCustomFieldValue() methods. Then the rest of the postfunction mechanism will take care of storing those values.
Another approach is to move your post function to the end of the post function sequence (after the store issue object function).
