Groovy errors
Andrew Striletskyi February 19, 2018
I have a script. Main task of this script is to assign issues in Round Robin fashion . But this script not working and I can't understand why. Anyone can help?
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.user.ApplicationUser;
import com.atlassian.jira.user.util.UserManager;
import com.atlassian.jira.security.groups.GroupManager;
import com.atlassian.jira.issue.search.SearchResults;
import com.atlassian.jira.issue.search.SearchProvider;
import com.atlassian.jira.jql.parser.JqlQueryParser;
import com.atlassian.jira.issue.MutableIssue;
import com.atlassian.jira.bc.issue.IssueService.IssueResult;
import com.atlassian.jira.bc.issue.IssueService;
import com.atlassian.jira.issue.IssueInputParameters;
import com.atlassian.jira.issue.Issue;
import com.atlassian.jira.web.bean.PagerFilter;
import java.sql.Timestamp;
class Agent {
ApplicationUser user;
int issueCount;
long lastAssignedTime;
def groupsList = ComponentAccessor.getGroupManager() as GroupManager
def groupMembers = groupsList.getUsersInGroup("NetOps")
def userManager = ComponentAccessor.getUserManager() as UserManager
def user = ComponentAccessor.jiraAuthenticationContext.loggedInUser
def jqlQueryParser = ComponentAccessor.getComponent(JqlQueryParser.class)
def searchProvider = ComponentAccessor.getComponent(SearchProvider.class)
def jqlQuery = "status != Closed and assignee=null ORDER BY created DESC"
def query = jqlQueryParser.parseQuery(jqlQuery)
def results = searchProvider.search(query,user,PagerFilter.getUnlimitedFilter())
assignAgent(user,results, agents, jqlQueryParser, searchProvider,agentPQ)
def getIssueCountForAgent(ApplicationUser agent ,JqlQueryParser jqlQueryParser, SearchProvider searchProvider ){
def jqlQuery = "assignee=\""+ agent.name + "\" and status!=Closed "+ " ORDER BY created DESC"
def results = searchProvider.search(query, agent, PagerFilter.getUnlimitedFilter())
return results.total
def getLastAssignedTimeForAgent(ApplicationUser agent, JqlQueryParser jqlQueryParser, SearchProvider searchProvider ){
if(results.issues.size() == 0)
return 0;
else{
def changeLogManager = ComponentAccessor.changeHistoryManager
def assignedAt = changeLogManager.getChangeItemsForField(results.issues.get(0),"assignee").find {
it.toString() == agent.name
}?.getCreated() as Timestamp
if(assignedAt){
Date d = new Date(assignedAt.getTime())
return d.getTime()
}else{
return 0
def assignAgent(ApplicationUser admin,SearchResults results ,Collection<ApplicationUser> agents, JqlQueryParser jqlQueryParser, SearchProvider searchProvider, PriorityQueue<Agent> agentPQ)
def issueManager = ComponentAccessor.issueManager
MutableIssue mutableIssue = issueManager.getIssueObject(results.issues.get(0).id)
agents.forEach { agent ->
log.debug("agent = "+agent)
Agent a = new Agent()
def count = getIssueCountForAgent(agent, jqlQueryParser , searchProvider)
if(count > 0) {
a.lastAssignedTime = getLastAssignedTimeForAgent(agent, jqlQueryParser , searchProvider)
a.issueCount = count
else {
a.lastAssignedTime = 0
a.issueCount = 0
a.user = agent
agentPQ.add(a)
mutableIssue.setAssignee(agentPQ.peek().user)
mutableIssue.store()
issueManager.updateIssue(admin, mutableIssue, createIssueUpdateRequest())
def issueService = ComponentAccessor.getIssueService()
IssueInputParameters params = ComponentAccessor.issueService.newIssueInputParameters()
params.assigneeId = agentPQ.peek().user.id
def validateUpdateResult = issueService.validateUpdate(admin,mutableIssue.id,params)
if(!validateUpdateResult.errorCollection.hasAnyErrors()){
log.debug("Assignee validated = " + validateUpdateResult.fieldValuesHolder.get("assigneeId"))
IssueService.IssueResult serviceResult=issueService.update(admin,validateUpdateResult)
log.debug(serviceResult)
else{
log.debug validateUpdateResult.errorCollection.errorMessages.toString()
Alexey Matveev
February 19, 2018
What are the errors?
For example in this line:
I see an error that  getIssueObject not defined or type is not correct for this method
Alexey Matveev
February 19, 2018
I guess, it is all static compilation. Moreover your code seems to me as broken. I am not sure it will work at all.
class Agent {
int issueCount;
Collection<ApplicationUser> agents = new ArrayList<ApplicationUser>()
PriorityQueue<Agent> agentPQ = new PriorityQueue<Agent>()
return 0;
else{
def assignedAt = changeLogManager.getChangeItemsForField(((Issue) results.issues.get(0)), "assignee").find {
if(assignedAt){
return d.getTime()
}else{
return 0
MutableIssue mutableIssue = issueManager.getIssueObject(((Issue)results.issues.get(0)).id)
def count = getIssueCountForAgent((ApplicationUser) agent, jqlQueryParser , searchProvider) as int
if(count > 0) {
a.lastAssignedTime = getLastAssignedTimeForAgent((ApplicationUser) agent, jqlQueryParser , searchProvider) as long
else {
a.issueCount = 0
a.user = (ApplicationUser) agent
agentPQ.add(a)
else{
There is a error only with createIssueUpdateRequest(). Because the method is not defined in your script
Andrew Striletskyi February 20, 2018
I fixed it , thank you) So, now the only problem is that the changes made by the script running as post-function is not reflecting in the assignee field.
Alexey Matveev
February 20, 2018
Your script is too long. I would advise you to make it shorter and try to save a value in the assignee field. Make the short script work. After it you can fix your long script.
