I am trying to use groovy script to pull issues and their change history for only certain fields (label, summary, status and a custom field) going back only a certain time frame (most likely using 3 months). I found this (https://docs.atlassian.com/software/jira/docs/api/7.6.1/com/atlassian/jira/issue/changehistory/ChangeHistoryManager.html) which shows how to pull issue history from a certain date and also for certain fields, but I can't use a specific date. I can't upload a new template to Jira each time with an updated date. Instead, I want to just pull the history going 3 months back from the current date at the time of export. And I want to only pull specific fields changed. I am using excel for this, so I want one column with the label, another with issue name (summary), another column with the field changed, and then a final column with the new value the field was changed to. I am looking for this (including the repeating but I can do that with macros as well) but narrowed down fields to avoid such a large export (https://www.midori-global.com/products/better-excel-exporter-for-jira/server/export-samples/jira-issues-excel-reports-with-comments-worklogs-history). Looking for groovy script for each column. Thank you!!
Hi, @Marleah Perry
Welcome to Atlassian Community.
You can try this code, that I made for similar tasks:
https://github.com/Udjin79/SRUtils/blob/master/org/evisaenkov/atlassian/library/HistoryOperations.groovy
You can pull history entries by custom field. Also you can write additional code to look at change date and filter only required changes.
Thank you!!
Make the most of your time in Barcelona with our curated guide – discover how Jira, Confluence, Loom, and Rovo work better together, connect with Atlassian experts, and enter to win an Apple prize bundle!
Get the guide
