Groovy script runner error 404 when merging a user
Claudio Ombrella
One of our JIRA systems in the company is moving to LDAP authentication. I am using the Groovy Script Runner on other systems and never had an issue. So this is what I did.
The first time I installed the latest beta. As it did not work, I disabled, uninstalled and then installed the latest release 2.0.11. I always have the same issue which is this message:
Not Found (404)
assert gvs.size() == 1 | | | | 2 false [[lastName:Becker, lowerEmailAddress:mario.becker@pi-vr.de, updatedDate:2012-05-15 12:25:55.867, directoryId:10001, emailAddress:mario.becker@pi-vr.de, credential:nopass, id:10015, lowerFirstName:mario, userName:mbecker, active:1, lowerLastName:becker, lowerDisplayName:mario becker, lowerUserName:mbecker, firstName:Mario, displayName:Mario Becker, createdDate:2011-11-03 12:11:33.21], [lastName:Becker, lowerEmailAddress:mb@pi-vr.de, updatedDate:2013-01-18 16:23:17.958, directoryId:1, emailAddress:mb@pi-vr.de, credential:{PKCS5S2}w8CKptZccADjlfA1N66Tb2hjy7ALXLOeyHSW9Hi0z2KBZgsFW/09+jB5OguEAxHn, id:10710, lowerFirstName:mario, userName:mbecker, active:1, lowerLastName:becker, lowerDisplayName:mario becker, lowerUserName:mbecker, firstName:Mario, displayName:Mario Becker, createdDate:2013-01-10 15:44:52.813]]
Could not find what you were looking for. Maybe you should raise an issue.
Did anyone come across the same issue? If yes how did you fix it?
Best regards
Claudio Ombrella
JamieA
January 19, 2013
Claudio... there are various issues here.
What's it trying to tell you, in a very confusing way, is that there is more than one user with the username you are trying to merge. This means they exist in more than one directory.
Because there is no way of specifying which directory you want to search in, the script is just bombing out. This was mostly laziness on my part, ie I should not use an assertion failure to stop execution... but most of this code was written before it was possible that you could have duplicate user names.
I'm not sure if I will update this code to handle this as it's very invasive, and Atlassian have committed to fixing this (ie allowing rename of users). Assuming you are trying to merge the two mbecker's together, I don't think you are going to be able to.
Claudio Ombrella
Thanks Jamie for your prompt answer. We have 1 JIRA Internal Directory plus 2 directories disabled (I will remove them) plus the new JIRA Internal Delegated Authentication. I will test tomorrow removing the 2 disabled and try again, probably you are right the user is defined with same ID in multuple directories. By the way in the new one (JIRA Internal Delegated Authentication) the user ID is different. More news tomorrow!
Have a nice Sunday!
Claudio
JamieA
January 19, 2013
Hi Claudio. Sounds good. If at all possible I would reproduce this on a copy of production, and only once you're happy with the steps should you repeat in production.
Apart from the internal dir, you can see mbecker is also in directory 10001. If you float your mouse over the "edit" operations or whatever on the directories you can see which one corresponds to 10001. If that's one of the disabled ones it should work if you delete that.
Claudio Ombrella
Hi Jamie:
I removed the disabled directories, we no longer needed them, but the error stil persists. I tried to disable and enable the plugin to clear any memory settings (though did not stop/start JIRA) and I keep getting the same error. Seems like the user is still defined internally in the user DB. What can we do next?
By the way now the error message changed. See screenshot below. It was not the same format before.
Thanks a lot
Claudio
JamieA
January 20, 2013
It seems to be the same error though... I'm afraid what this means is you can't use script runner to do anything with this user.
*If* you have this in test, and you trying to merge both mbecker's, I think you can try to delete one of them from cwd_user. You will lose whichever group memberships the one you delete has. After that both mbecker's should be the same. The other thing is to try jira 5.2 where there is a merge directory (or something) option.
Ethan Bonick March 27, 2013
What I have found in my testing is you can move the group by updating the cwd_group table just change the directory_id to the new directory id, this will move the groups. Just make sure to not already have the same groups created in the new directory. We had an internal directory went to AD and now have to merge users to a new AD from the company that just bought us. Our internal and original AD had the same user names. This has NOT been fully tested but initial indications show it worked.
