Hi Team,
We are working on the case where whenever the ticket of this project is updated, let's say Field tower should be made mandate whenever any changes made by JIRA user in Assignee field.
So whenever user changes assignee of the ticket , the field tower should be made mandatory, so that even if users forgets to update field tower and clicks update , a pop will arise saying provide value for mandatory field. In our case it's already mandate and tried to run this groovy script as well but doesn't seem to work :
import com.atlassian.jira.issue.CustomFieldManager
import org.apache.log4j.Category
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
import com.atlassian.jira.issue.ModifiedValue
import org.apache.log4j.Logger
import org.apache.log4j.Level
//Get the field tower for update
def TowerValue = getFieldById("Tower");
//Grab Assignee in edit view
def AssigneeName = getFieldById(getFieldChanged());
//grab current Assignee from database
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager();
CustomField currentAssignee = customFieldManager.getCustomFieldObject("Assignee");
//see assignee was changed in edit view (note null safe operator [?] which allow tower to be null without throwing an exception)
if((AssigneeName ?.value) != currentAssignee) {
//clear Tower field
TowerValue.setFormValue(null);
//require Tower field so that user is forced to enter text
TowerValue.setRequired(true);
else {
TowerValue.setRequired(false);
Also could you help us guiding where this script should be running in behaviour : initialiser / under filed tower (server side - script)/ under Field Assignee (server side - script)
Priyanka.
You should add Assignee to the list of Fields in your Behaviour setup.
I have made some pseudo Groovy code which should be triggered when the Assignee field is changed.
def towerValue = getFieldById("Tower")
def assigneeField = getFieldById(getFieldChanged())
if((assigneeField?.value) != currentAssignee) {
// Show and set required
towerValue?.setHidden(false)
towerValue?.setRequired(true)
} else {
// Hide and unset required
towerValue?.setHidden(true)
towerValue?.setRequired(false)
Hope this will get you further.
Regards
Lasse Langhorn
Thanks for your reply, But this doesn't work .
So whenever i am trying to change assignee , there is no change in tower field , neither the "if " condition is getting executed nor the "else" one.
Could you please help me to understand the difference between getFieldByName & getFieldById ? ( as this has some effect on code when i tried to change it for both fields ).
And which assignee are these statements representing :
Priyanka.
The following code applies to the field that your Behavior code is meant to execute.
The following code makes the assumption that there is a custom field name Assignee but Assignee is a Jira system field. This is wrong, my bad.
What about the following code:
def currentAssignee = getFieldById("assignee")
CustomField towerValue = customFieldManager.getCustomFieldObject("Tower")
} else {
You can read more about Behaviors here.
Regards
Lasse Langhorn
Help us plant more trees
