  • Community
  • Q&A
  • Jira
  • Questions
  • Groovy script to create field when user select Any-Other option from select list new textbox create
AKSHAY THAKARE
Guys can you provide me the Groovy script for the following functionality.
I want to add such functionality that when the user selects Any-Other option from the select list then automatically new text field generate where a user can write anything for the text Custom filed. This should be done while user raising any request.
for eg.
product type-    [ Project 1]
                          [  Project 2]
                         [  Any-Other]
 when user select Any -Other  then new text field need be create  [___________________]
 enter
Adrián Plaza [DEISER]
July 23, 2018
Hi @AKSHAY THAKARE,
This functionality is not by default in Jira Service Desk, you need to use an App for this purpose like https://marketplace.atlassian.com/apps/1212161/extension-for-jira-service-desk?hosting=server&tab=overview
You need to review the Dynamics Forms functionality: https://deviniti.com/support/addon/server/extension/latest/dynamic-forms/
I hope this help,
Adrián.
AKSHAY THAKARE
HI @Adrián Plaza [DEISER]
Thanks for the solution. can you please provide me the exact process?
Currently, I have created the field with name product name with select list how can I conditionaly add text box when user select other option.
July 23, 2018
Hi @AKSHAY THAKARE
Try to follow this guide: https://deviniti.com/support/addon/server/extension/latest/df-project-conf/
if you have problems I can help you.
Adrián.
AKSHAY THAKARE
I followed the same process as in guide but I was not getting the expected result. I used multiple select for the products. should I use a single select list so I can get the result?
