I'm looking for a way to group Jira filter results by a specific field and control the columns that are displayed to summarize the information. For example, I want to review:
The "Single Level Group By Report" is basically what I'm looking for except that I can't control the columns that are shown. So I'm not getting the critical information that I need in my summary.
A confluence page would do fine. I tried the Jira Issue macro but it doesn't give me any formatting options. It's just a list of issues exactly like Jira. I may as well use Jira.
I found an awesome twiki plugin that does exactly what I want: http://twiki.org/cgi-bin/view/Plugins/JiraPlugin. It offers the perfect mix of control and simplicity: I can manage my JQL query and control the formatting including Group By.
How can I get this functionality using Jira and/or Confluence?
@Bert Michaud - You may want to give EazyBI a try. it's available for Cloud and Server. It may be overkill for a single report, but you may find your organization could use it in other contexts.
If you're comfortable with writing SQL queries and use Confluence, you could use the Bob Swift SQL add-on which lets you run queries and display their results (as a table, as a chart, etc.) within a Confluence page. This recipe gives you a quick sense of how it would work.
You'll need to do a bit of coding, but this tutorial - https://developer.atlassian.com/display/JIRADEV/Creating+a+JIRA+Report, specifically the 'Single Level Group By Extended report' should get you there. the good news is the code is downloadable, so much of the hard lifting has been done.
Thanks - that would accomplish the goal. Unfortunately I don't have admin access so this will be difficult to get done. I'll see if we can plan it out with the admins.
I'm frustrated that the product has 2 extremes: on the one extreme, the product tries to think for me and only provides very basic formatting options. On the other extreme, I have to code up a plugin to add a column to a report.
What I'm really looking for is something like what that Twiki Jira plugin offers (see link in my original post). It has some really straight forward table formatting capabilities with no coding. I could create 6 different custom reports in less than 1 hour.
Is there any other option? Maybe a way to do it in Confluence without using the Jira Issues Macro? (it doesn't allow for any formatting)
I very much agree with Bert... the prerequisites for that tutorial are pretty damn specific! I don't want to become a Java / Apache Velocity template developer to get a grouped report in Confluence! This seems like an obvious want and it would be good if it was out of the box in Confluence or JIRA.
To complete this tutorial, you need to know the following:
