Group Sign-Off plugin - How to disable voting once issue is transited to Approved/Rejected state
Purandhar Krishnamurthy
I would like to know how to disable voting once the issue is transited to specific (say Approved/Rejected) state. For example,
  • Initially the issue is waiting for approvals and in a state called ‘Waiting for Approval’
  • After user votes, issue is signed-off and issue state is transited to ‘Approved’ state, I want to disable the users from voting and/or changing their votes. Similarly, after enough votes have voted to ‘decline’ and issue is moved to ‘Declined’ state, I want to disable the users from voting or changing their votes.
Pratik
Hi Joao,
Thanks for the reply. I think you are talking about jira's inbuilt voting feature. I was asking about group-signoff plugin.
Purandhar
João Palharini
May 25, 2015
Hi Purandhar!
You can achieve this with the built-in properties in JIRA's workflows. To add this property, do the following:
  1. Go to AdministrationIssuesWorkflows;
  2. Click Edit on the right of the workflow you use for the project you want to have this property added;
  3. On the right step you want to deny voting, click View Properties;
  4. Add jira.permission.vote.denied on the Property Key field;
  5. Click Add;
  6. Go back to the screen with the steps;
  7. Click Publish Draft on the top of the page;
  8. Save the modified workflow;
Now users shouldn't be able to vote on issues that are on that step.
Cheers!
Joao
