Group Usage
Sushant Verma
November 23, 2022
I need to create a report of Crowd group usage in Jira Projects and Confluence Space. I would not want to filter it based on Organization not. But we need to get a way to identify which projects are using any crowd group. It can be a consolidated report or an excel macro which the user can try to input a crowd group name to it and then search for any Jira Project and Confluence space that uses it and against what role.
Brant Schroeder
November 23, 2022
@Sushant Verma
If you have SQL access you can get the groups and project roles from the DB - https://confluence.atlassian.com/jirakb/how-to-get-a-list-of-permissions-granted-to-groups-assigned-to-project-roles-790630266.html
You can do something similar in Confluence - https://confluence.atlassian.com/confkb/how-to-list-which-spaces-a-group-can-access-720636535.html
You might need to tweak the SQL to get exactly what you need but this should get you started in the right direction.
Sushant Verma
November 24, 2022
Thanks @Brant Schroeder
Brant Schroeder
November 26, 2022
@Sushant Verma if this was helpful can you please mark as accepted to help others.
Dang Thi Thuy Tien
February 3, 2025
Hi!
Tracking group usage in Jira/Confluence can be a challenge, but Group Master for Jira/Confluence makes it simple! You can easily see where each group is being used across all your projects—no more searching or guessing. It’s all in one place, making things way more organized. You also can export the usage of group as CSV
Give it a try and see how easy it can be!
https://marketplace.atlassian.com/apps/1236395/group-master-for-jira?hosting=datacenter&tab=overview
https://marketplace.atlassian.com/apps/1236396/group-master-for-confluence?hosting=datacenter&tab=overview
And another advanced group management capabilities:
    View group usage across Jira
    Edit group names for clarity
    Move or copy group members easily
    Replicate or migrate group usage
    Delete groups and clean up associated data
