Group User JIRA workflow validator
Darly Senecal-Baptiste
June 25, 2014
Hi Community.
I am looking for a practice (or plugin) in which at certain workflow transition, a user is selected at the transition screen, and once before transitioning the issue to its next state, jira must validate that the selected user belongs to a group. I want to know how to implement this.
Regards
Vijay Khacharia
June 26, 2014
You can do a validator for group check using the script runner plugin.
Use the validator Scripted Validator -> "Simple Scripted Validator" -> put the code in condition box and message that is to be displayed when condition is not true.
There is already a example for reporter not in group. You can modifiy reporter to the field you want to check the user from.
Vijay
Danilo Conrad
June 25, 2014
Hi Darly,
You may implement a User Is In Group condition in the workflow, following the instructions on the document below:
https://confluence.atlassian.com/display/JIRA/Advanced+workflow+configuration
I hope this helps.
Danilo
