Is it possible to update an Assets Object using HAPI without trigger Asset Listeners?
setEventDispatchOption(EventDispatchOption.DO_NOT_DISPATCH)
This works on a HAPI issue update, but not a HAPI Assets Update?
Have you tried using the approach below with ScriptRunner's HAPI, i.e.:-
issue.update {
//Field to update
for example:-
issue.update {
setDescription('Testing 123')
setCustomFieldValue('Sample Text', 'Abc 123')
Using the approach above, you do not need to trigger the Event Dispatcher.
I hope this helps to answer your question. :)
Thank you and Kind regards,
Ram
Register now
