HOW CAN I CONNECT JIRA DATABASE WITH MY WEB APP
swaraj jaiswal April 3, 2013
HI,
I am using JIRA, its very gud tool,can you guide me how to use the database that JIRA is using the same database in my web application.? i.e the data i feed in JIRA will reflect in my web application.
Nic Brough -Adaptavist-
April 3, 2013
That's rather a vague question, but the most useful answer is probably "Get your other application to read Jira over a REST connection"
Forget the database - that's quite complex and likely to change definition, whereas REST exposes stuff that is accessible, human friendly and less likely to change (example - the whole user database was ripped out and replaced by a totally different system. You'd have had to rewrite all your SQL from scratch. The external interfaces didn't even notice)
Start at http://docs.atlassian.com/jira/REST/latest/
Learn more
