HP ALM integration to Confluence
SamVijay May 21, 2019
Step by Steps  process the HP ALM integration to Confluence.
Where we want to import the Test cases  results & Test case logs in to Confluence.
Nic Brough -Adaptavist-
May 21, 2019
"Integration" is too vague a word for us to help you with, beyond saying "use the REST API".
Importing logs and test cases should be simple though - with REST, either get your test tool to push new pages or attachments into Confluence as it creates them.
We want to import the Test cases & Test logs in to confluence that was are planning to to do. Can you guid me with the steps how to be done.So i can take it to the confluence admin .
Need what are the requirements to there, is there any cost is involved for this import
Is REST API  is available in Confluence?
May 22, 2019
Start at https://developer.atlassian.com/server/confluence/confluence-server-rest-api/ - you'll need to look at the parts about creating pages and possibly attaching things.  The examples section contains some simple code for both of those
Register today
