For the time being, you can place raw HTML tags in field descriptions. Atlassian has stated they plan to remove this functionality.
Ok, no HTML tag support in Custom Field's Description.
I want to enter / display HTML code into Custom Feild (Text Field (multi-line))'s Description.
First of all, HTML is supported into Cusotm Field's Description? If yes, is there any same code?
p.s. I have been using JIRA Server 6.4.13 now.
