HTTP Basic authentication not working anymore for jira.atlassian.com REST API
Raimonds Simanovskis
February 15, 2015
Hi
We were using jira.atlassian.com REST API to load some test JIRA data in our eazyBI reporting application and we were using REST API with HTTP Basic authentication (as otherwise some APIs like "user" didn't return any results) and using our jira.atlassian.com username and password. At least still in January 30 it was working.
But couple days ago I discovered that simple https://jira.atlassian.com/rest/api/latest/serverInfo with my username and password in HTTP Basic authentication header returns 403 Forbidden response.
If I try another Atlassian JIRA site, for example, https://ecosystem.atlassian.net/rest/api/latest/serverInfo with HTTP Basic authentication then it still works.
Does anyone knows what has changed in jira.atlassian.com authentication in recent weeks and why Basic authentication is not working anymore?
Raimonds
peterb
February 18, 2015
You have to use Atlassian ID when you are logging in to jira.atlassian.com.
I have tested these commands and they work for me.
  1. Log in using Atlassian ID Rest resource and retrieve token:
  2. curl \
        -i -X POST \
        -H "Content-Type: application/json"\
        --data '{"username": "foobar@example.com", "password": "foobar"}'
    Response:
    TTP/1.1200OK
    Server: nginx
    Date: Mon, 03Feb 201405:57:27GMT
    Transfer-Encoding: chunked
    Connection: keep-alive
    X-Frame-Options: DENY
    P3P: CP="This is not a P3P policy! See http://www.atlassian.com/company/privacy for more info."
    Set-Cookie: __ATL_TOKEN=L33TT0KEN; Version=1; Domain=.atlassian.com; Path=/; HttpOnly
    {"username":"foobar@example.com","xsrfToken":"xsrfToken","firstName":"Foo","lastName":"Bar"}
  3. Use the given cookie __ATL_TOKEN for subsequent requests
    curl \
        -D- -X GET \
        -H "Cookie:__ATL_TOKEN=L33TT0KEN; Version=1; Domain=.atlassian.com; Path=/; HttpOnly"\
February 18, 2015
My question is about jira.atlassian.com. As I said I was using my Atlassian ID for HTTP Basic authentication and jira.atlassian.com REST API was working with it until end of January. But something has changed in February and now just for jira.atlassian.com site REST API with HTTP Basic authentication is returning 403 Forbidden response.
Like • Artur Fazylov likes this
Nikita Marchenko February 18, 2015
The server at extranet.atlassian.com can't be found, because the DNS lookup failed. Can you provide another url?
peterb
February 23, 2015
I will copy content from that page and paste it in a new answer.
peterb
February 23, 2015
Actually, I've edited this question instead.
peterb
February 23, 2015
Aargh, I mean this answer to the question.
March 2, 2015
Thanks, this is working for us as a workaround. But do you know the reason why normal HTTP Basic authentication is not working anymore for jira.atlassian.com?
peterb
March 2, 2015
I'm told that it's because Atlassian ID is now mandatory on this server.
I have a problem with basic auth too. Got 401. I tried culr wget http python-request. Samples from https://developer.atlassian.com/jiradev/api-reference/jira-rest-apis/jira-rest-api-tutorials/jira-rest-api-example-basic-authentication don't work. Please help.
peterb
February 18, 2015
Are you querying jira.atlassian.com, a local dev instance of JIRA or another instance?
mirantis.jira.com and https://vetakoko.atlassian.net
Nikita Marchenko February 19, 2015
I found solution. I use email as login instead of username in jira. Please write this to doc file.
