  • Community
  • Q&A
  • Jira
  • Questions
  • HTTP Status 500 - Exception occurred while rendering template 'templates/jira/appconsistency/jiralocked.vm'.
seunghwan myong
May 10, 2015
i was  migrate JIRA to another server
and backup files moved to new server
i followed https://confluence.atlassian.com/display/JIRA/Migrating+JIRA+to+Another+Server
attach the /logs/catalina.out
user.timezone : Etc/UTC
2015-05-10 13:03:52,676 localhost-startStop-1 FATAL [atlassian.jira.startup.JiraStartupLogger]
Could not create subdirectory 'plugins' of jira.home '/data/var'.
log4j:ERROR setFile(null,true) call failed.
java.io.FileNotFoundException: atlassian-jira.log (Permission denied)
at java.io.FileOutputStream.open0(Native Method)
at java.io.FileOutputStream.open(FileOutputStream.java:270)
at java.io.FileOutputStream.<init>(FileOutputStream.java:213)
at java.io.FileOutputStream.<init>(FileOutputStream.java:133)
at org.apache.log4j.FileAppender.setFile(FileAppender.java:294)
at org.apache.log4j.RollingFileAppender.setFile(RollingFileAppender.java:207)
at org.apache.log4j.FileAppender.activateOptions(FileAppender.java:165)
at com.atlassian.jira.logging.JiraHomeAppender.configureAppender(JiraHomeAppender.java:341)
at com.atlassian.jira.logging.JiraHomeAppender.doAppendSync(JiraHomeAppender.java:267)
at com.atlassian.jira.logging.JiraHomeAppender.doAppend(JiraHomeAppender.java:248)
at org.apache.log4j.helpers.AppenderAttachableImpl.appendLoopOnAppenders(AppenderAttachableImpl.java:66)
at org.apache.log4j.Category.callAppenders(Category.java:206)
at org.apache.log4j.Category.forcedLog(Category.java:391)
at org.apache.log4j.Category.log(Category.java:838)
at com.atlassian.jira.startup.FormattedLogMsg.printMessageImpl(FormattedLogMsg.java:222)
at com.atlassian.jira.startup.FormattedLogMsg.printMessage(FormattedLogMsg.java:214)
at com.atlassian.jira.startup.JiraStartupLogger.printMessage(JiraStartupLogger.java:59)
at com.atlassian.jira.startup.StartupStateTemplate$CreateStartupChecksResult.call(StartupStateTemplate.java:124)
at com.atlassian.jira.startup.StartupStateTemplate$CreateStartupChecksResult.call(StartupStateTemplate.java:115)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at com.atlassian.jira.startup.StartupStateTemplate.isStartupChecksPassed(StartupStateTemplate.java:47)
at com.atlassian.jira.startup.JiraStartupChecklist.startupOK(JiraStartupChecklist.java:52)
at com.atlassian.jira.startup.BootstrapContainerLauncher.bootstrapJIRA(BootstrapContainerLauncher.java:52)
at com.atlassian.jira.startup.BootstrapContainerLauncher.start(BootstrapContainerLauncher.java:31)
at com.atlassian.jira.startup.DefaultJiraLauncher.preDbLaunch(DefaultJiraLauncher.java:98)
at com.atlassian.jira.startup.DefaultJiraLauncher.access$000(DefaultJiraLauncher.java:33)
at com.atlassian.jira.startup.DefaultJiraLauncher$1.run(DefaultJiraLauncher.java:85)
at com.atlassian.jira.util.devspeed.JiraDevSpeedTimer.run(JiraDevSpeedTimer.java:34)
at com.atlassian.jira.startup.DefaultJiraLauncher.start(DefaultJiraLauncher.java:81)
at com.atlassian.jira.startup.LauncherContextListener.contextInitialized(LauncherContextListener.java:72)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4992)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5490)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1575)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1565)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
2015-05-10 13:03:52,683 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger] Running JIRA startup checks.
2015-05-10 13:03:52,683 localhost-startStop-1 FATAL [atlassian.jira.startup.JiraStartupLogger] Startup check failed. JIRA will be locked.
2015-05-10 13:03:52,760 localhost-startStop-1 INFO [jira.config.database.SystemDatabaseConfigurationLoader] Reading database configuration from /data/var/dbconfig.xml
2015-05-10 13:03:53,104 localhost-startStop-1 INFO [atlassian.jira.startup.LauncherContextListener] Memory Usage:
Heap memory : Used: 76 MiB. Committed: 460 MiB. Max: 718 MiB
Non-heap memory : Used: 32 MiB. Committed: 34 MiB. Max: 1264 MiB
TOTAL : Used: 108 MiB. Committed: 494 MiB. Max: 1982 MiB
2015-05-10 13:03:53,400 localhost-startStop-1 WARN [jira.config.properties.ApplicationPropertiesStore] Exception getting property 'jira.trustedapps.user.name.transformation.policy.class' from database. Using default
2015-05-10 13:03:53,564 localhost-startStop-1 ERROR [jira.web.dispatcher.JiraWebworkActionDispatcher]
JIRA startup failed, JIRA has been locked.
May 10, 2015 1:03:53 PM org.apache.catalina.startup.HostConfig start
SEVERE: Unable to create directory for deployment: /data/jira/conf/Catalina/localhost
May 10, 2015 1:03:53 PM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-bio-8080"]
May 10, 2015 1:03:53 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 9555 ms
2015-05-10 13:03:53,935 http-bio-8080-exec-2 ERROR anonymous 783x2x1 - 125.57.206.11 /JiraLockedError [jira.template.velocity.VelocityEngineFactory$Default] Exception initialising Velocity: java.lang.RuntimeException: org.apache.velocity.util.ClassConstructionException: Cannot instantiate class for introspector.cache.classes
at com.atlassian.velocity.htmlsafe.introspection.AnnotationBoxingUberspect.init(AnnotationBoxingUberspect.java:59)
at org.apache.velocity.runtime.RuntimeInstance.initializeIntrospection(RuntimeInstance.java:366)
at org.apache.velocity.runtime.RuntimeInstance.init(RuntimeInstance.java:255)
at org.apache.velocity.runtime.RuntimeInstance.init(RuntimeInstance.java:588)
at org.apache.velocity.app.VelocityEngine.init(VelocityEngine.java:135)
at com.atlassian.jira.template.velocity.VelocityEngineFactory$Default.initialise(VelocityEngineFactory.java:70)
at com.atlassian.jira.template.velocity.VelocityEngineFactory$Default.access$000(VelocityEngineFactory.java:24)
at com.atlassian.jira.template.velocity.VelocityEngineFactory$Default$1.create(VelocityEngineFactory.java:35)
at com.atlassian.jira.template.velocity.VelocityEngineFactory$Default$1.create(VelocityEngineFactory.java:30)
at com.atlassian.util.concurrent.LazyReference$Sync.run(LazyReference.java:325)
at com.atlassian.util.concurrent.LazyReference.getInterruptibly(LazyReference.java:143)
at com.atlassian.util.concurrent.LazyReference.get(LazyReference.java:112)
at com.atlassian.jira.template.velocity.VelocityEngineFactory$Default.getEngine(VelocityEngineFactory.java:47)
at com.atlassian.jira.startup.JiraStartupChecklistFilter.getVelocityEngine(JiraStartupChecklistFilter.java:117)
at com.atlassian.jira.startup.JiraStartupChecklistFilter.doFilter(JiraStartupChecklistFilter.java:98)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at com.atlassian.jira.web.filters.MultipartBoundaryCheckFilter.doFilter(MultipartBoundaryCheckFilter.java:41)
at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:87)
at com.atlassian.jira.web.filters.JiraFirstFilter.doFilter(JiraFirstFilter.java:61)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1070)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:611)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:316)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
Caused by: org.apache.velocity.util.ClassConstructionException: Cannot instantiate class for introspector.cache.classes
at org.apache.velocity.util.introspection.IntrospectorBase.<init>(IntrospectorBase.java:81)
at org.apache.velocity.util.introspection.Introspector.<init>(Introspector.java:65)
at org.apache.velocity.util.introspection.UberspectImpl.init(UberspectImpl.java:66)
at com.atlassian.velocity.htmlsafe.introspection.AnnotationBoxingUberspect.init(AnnotationBoxingUberspect.java:55)
... 38 more
Caused by: org.apache.velocity.util.ClassConstructionException: java.lang.reflect.InvocationTargetException
at org.apache.velocity.util.ClassUtils.getNewInstance(ClassUtils.java:180)
at org.apache.velocity.util.introspection.IntrospectorBase.<init>(IntrospectorBase.java:77)
... 41 more
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:422)
at org.apache.velocity.util.ClassUtils.getNewInstance(ClassUtils.java:168)
... 42 more
Caused by: java.lang.NullPointerException
at com.atlassian.velocity.JiraIntrospectorCache.<init>(JiraIntrospectorCache.java:32)
... 47 more
May 10, 2015 1:24:34 PM org.apache.catalina.core.StandardServer await
INFO: A valid shutdown command was received via the shutdown port. Stopping the Server instance.
May 10, 2015 1:24:34 PM org.apache.coyote.AbstractProtocol pause
INFO: Pausing ProtocolHandler ["http-bio-8080"]
May 10, 2015 1:24:34 PM org.apache.catalina.core.StandardService stopInternal
INFO: Stopping service Catalina
java.io.FileNotFoundException: atlassian-jira-security.log (Permission denied)
at org.apache.log4j.Category.log(Category.java:856)
at org.slf4j.impl.Log4jLoggerAdapter.warn(Log4jLoggerAdapter.java:400)
at com.atlassian.seraph.filter.SecurityFilter.destroy(SecurityFilter.java:70)
at org.apache.catalina.core.ApplicationFilterConfig.release(ApplicationFilterConfig.java:313)
at org.apache.catalina.core.StandardContext.filterStop(StandardContext.java:4864)
at org.apache.catalina.core.StandardContext.stopInternal(StandardContext.java:5677)
at org.apache.catalina.util.LifecycleBase.stop(LifecycleBase.java:232)
at org.apache.catalina.core.ContainerBase$StopChild.call(ContainerBase.java:1591)
at org.apache.catalina.core.ContainerBase$StopChild.call(ContainerBase.java:1580)
2015-05-10 13:24:34,539 localhost-startStop-2 INFO [atlassian.jira.startup.DefaultJiraLauncher] Stopping launchers
May 10, 2015 1:24:34 PM org.apache.coyote.AbstractProtocol stop
INFO: Stopping ProtocolHandler ["http-bio-8080"]
May 10, 2015 1:24:34 PM org.apache.coyote.AbstractProtocol destroy
INFO: Destroying ProtocolHandler ["http-bio-8080"]
please answer me
thanks
Nic Brough -Adaptavist-
May 10, 2015
The permissions on your new file system are wrong.
You need to make sure the operating system user running JIRA has full read/write/execute/delete permissions on all the directories and subdirectories it uses.  There's one for "JIRA installation" and another for "JIRA home" - it looks to me like you're using /data/var for "JIRA home" and the permissions there are wrong.
PAS February 23, 2017
Hi Nic,
You are right. We received the same error message. When we change the user that run the JIRA in the system from "jira" to "root", everything started up and run properly.
The thing is how can we tell which directories that the "jira" user need full permission to?
Thank you,
